Evo Notebook N1020v - Installing an Diskette Drive
Removing the Diskette Drive
  1. Prepare the computer for disassembly.
  2. Remove the palm rest.
  3. Turn the palm rest bottom side up with the speaker grilles facing away from you.
  4. Remove the three TM2.5 x 5.0 screws1 that secure the diskette drive to the palm rest.
  5. Remove the diskette drive2 from the palm rest.
  1. Release the ZIF connector1 to which the diskette drive cable is connected and disconnect the diskette drive cable2 from the drive.
  2. Remove the diskette drive cable.
Installing the Diskette Drive
Reverse the preceding procedures to install a Diskette Drive.
