Business Notebook NC4000 - Technical Specifications
System Unit
Item
Specification
Dimensions (H x W x D)
12.1-inch TFT panel display
1.1 x 11 x 9.2in/2.79 x 27.94 x 23.37cm
3.5 lb/1.58 kg
Stand-Alone Power Requirements
Nominal Operating Voltage
(Li-Ion)
14.8 VDC
Maximum Operating Power
40 W
Peak Operating Power
50 W
Temperature
Operating
50 to 95 F/10 to 35 C
Non-operating
4 to 140 F/20 to 60 C
Relative Humidity
Operating
10% to 90% relative humidity, non-condensing
Non-operating
5% to 90% relative humidity, 101.6 F/38.7 C maximum wet bulb temperature
Shock
Operating
40 G, 2 ms, half-sine
Non-operating
240 G, 2 ms, half-sine
Vibration
Operating
0.5 G, 10 to 500 Hz, 0.5 Oct/Min sweep rate
Non-operating
1.0 G, 10 to 500 Hz, 0.5 Oct/Min sweep rate
Maximum Altitude (unpressurized)
Operating
0 to 10,000 ft/3,048 m (14.7 to 10.1 psia)
Non-operating
0 to 30,000 ft/9,144 m (14.7 to 4.4 psia)
 Industry Standard Certifications
Blue Angel -
No
UL -
Yes
CSA -
Yes
VDE/TUV -
Yes
Nordic Safety -
Yes
Mexican Safety-
Yes
Poland Compliance-
Yes
