TFT 5000 Flat Panel Touchscreen Display - Operating the Monitor
Front Panel Controls
No.
Control
Function
1
Menu Button
  1. Launches first and second-level on-screen menus.
  2. Exits menus and on-screen display.
2
Minus Button
Selects and adjusts the functions.
3
Plus Button
4
Power Switch
Turns the monitor on and off.
5
Power LED
  1. Green indicates monitor is turned on.
  2. Yellow indicates suspend mode.
  3. Amber indicates sleep mode.
  4. Blinking Amber indicates Sleep Timer.
On-Screen Display Settings
Screen adjustments are located in the on-screen display (OSD) and can be viewed in one of six available languages. The following menus show the functions at each level:
OSD Menu (Analog)
Level 1 Menu
Level 2 Menu
Level 3 Menu
Brightness
Adjustment scale
N/A
Contrast
Adjustment scale
N/A
Position
Horizontal Position
Vertical Position
Cancel
Save and Return
Adjustment scale
Adjustment scale
Digital Conversion
Clock
Clock Phase
Clock Phase File
Cancel
Save and Return
Adjustment scale
Adjustment scale
Adjustment scale
Color
9300 K
6500 K
Custom Color
Cancel
Save and Return
Adjustment scale
Adjustment scale
Color adjustment scale
Language
Deutsch
English
Espanol
Francais
Italiano
Nederlands
Cancel
Save and Return
N/A
Management
Full Screen
Power Saver
Mode Display
Serial No.
Sleep Timer
Basic Main Menu
Cancel
Save and Return
No Yes
No Yes
No Yes
Displays Serial Number
Set Time and On/Off Times
Factory Reset
Confirm Reset
N/A
Exit
N/A
N/A
