Evo N180 - Installing the LED Cover
Removing the LED Cover
  1. Prepare the computer for disassembly.
  2. Turn the computer bottom side up with the rear panel facing forward.
  3. Remove the two PM2.0 x 8.0 screws that secure the LED cover to the base enclosure (Figure 5-12).
  4. Turn the computer top side up with the front facing forward.
  5. Open the computer.
  6. Press the ESC key to reveal the notch 1 in the LED cover (Figure 5-13).
  7. Insert a flat-bladed tool in the notch and lift the left side of the LED cover 2 .
  8. Remove the LED cover 3 .
Reverse the above procedure to install the LED cover.
