Evo Notebook N800c - Installing the Keyboard
Removing the Keyboard
  1. Prepare the computer for disassembly.
  2. Remove the LED cover
  3. Lift the back edge of the keyboard 1
  4. Slide the keyboard toward the back of the computer 2
  5. Lift the back edge of the keyboard and swing it forward 3 until it rests on the palm rest.
  1. Remove the two PM2.0 x 4.0 screws 1 that secure the keyboard shield to the base enclosure
  2. Remove the keyboard shield
  1. Release the ZIF connector 1 to which the keyboard cable is connected and disconnect the keyboard cable 2 from the system board
  2. Remove the keyboard.
Reverse the above procedure to replace the keyboard.
