HP Compaq nc8000 and nw8000 notebooks - Installing the Heat Sink
Overview
  1. Release the keyboard.
  2. Remove the five screws (1) that secure the heat sink to the notebook.
  3. Lift the front edge of the heat sink (2) to unseat the adhesive grip of the thermal grease on the processor.
  4. Swing the heat sink in a counterclockwise motion (3) until the back of the heat sink (4) clears the notebook.
  5. Remove the heat sink.
  1. Carefully clean any thermal grease residue from the heat sink (1) and processor surfaces (2) each time you remove the heat sink.
  2. Apply new thermal grease to both surfaces.
  3. Reverse the above procedure to install the heat sink.
Country: Flag Serbia
