HP Compaq Business Notebook nx5000 - Installing the Keyboard
Overview
  1. Turn the notebook upside down, with the front facing you.
  2. Remove the two screws that secure the keyboard to the notebook.
  3. Turn the notebook right-side up, with the front facing you.
  4. Open the notebook.
  5. Slide the four tabs on the top edge of the keyboard toward you (1).
  6. Lift the rear edge of the keyboard up and swing it forward (2) until it rests on the palm rest.
  7. Release the zero insertion force (ZIF) connector (1) to which the pointing stick cable is attached and disconnect the cable (2).
  8. Release the ZIF connector (3) to which the keyboard cable is attached and disconnect the cable (4).
  9. Reverse the above procedure to install the keyboard.
Country: Flag Serbia
