Evo N200 - Installing MEU
Installing MEU
To prevent a possible loss of data, save all files, close all applications, and turn off power to the computer before connecting to the MEU.
  1. Close the computer display.
  2. Align the computer between the MEU guide rails.
Connecting the MEU Without an Optional External Battery Pack
If an optional external battery pack is not attached to the computer, push the computer toward the expansion connector until the computer is docked.
Connecting the MEU With an Optional External Battery Pack
If an optional external battery pack is attached to the computer:
  1. Rotate the battery down into the recess of the MEU.
  2. Push the computer  toward the expansion connector until the computer is docked.
Be sure the battery is fully seated in the MEU recess so the connectors on the rear of the computer are exposed. Failure to fully expose the connectors prevents the computer from properly docking in the MEU.
Disconnecting the MEU
To prevent a possible loss of data, save all files, close all applications, and turn off power to the computer before disconnecting from the MEU.
  2. Pull the release lever forward.
  3. Disconnect the computer from the MEU.
Disconnecting the MEU Without an Optional External Battery Pack
If an optional external battery pack is not attached to the computer, remove the computer by sliding it forward, then tilting it up and away from the MEU expansion connector.
Disconnecting the MEU With an Optional External Battery Pack
If an optional external battery pack is attached to the computer, remove the computer by sliding it forward and lifting it straight up from the MEU.
Do not rotate the battery out of the MEU recess when disconnecting from the MEU; doing so can damage the connectors and prevent you from disconnecting properly.
