HP iPAQ hx2000 series Pocket PC - Specifications
System Specifications
Feature
Models
hx2750
hx2410
hx2110
Integrated communications
Wi-Fi (802.11b), Bluetooth, IrDA (SIR), USB Client, Serial RS232
Microsoft Windows Mobile 2003 Second Edition software for Pocket PC
Pocket versions of Microsoft software are included (Outlook, Word, Excel and Internet Explorer for Pocket PC)
Processor
Intel PXA270 Processor 624 MHz
Intel PXA270 Processor 520 MHz
Intel PXA270 Processor 312 MHz
Memory
256 MB total memory (128 MB ROM and 128 MB SDRAM) Up to 185 MB user available memory that includes 80 MB iPAQ File Store
128 MB total memory (64 MB ROM and 64 MB SDRAM) Up to 65 MB user available memory that includes 20 MB iPAQ File Store
Security
Biometric fingerprint reader HP ProtectTools secured by CREDANT Technologies
3.5” transflective TFT QVGA color, 64K colors, LED backlight with power save mode; portrait and landscape mode
Indicators
LED 1- Power
Solid amber LED (right) – battery in unit fully charged
Flashing amber LED (right) – battery in unit is charging
Flashing green LED (right) – event alarm/notification
LED 2- Wireless
Flashing blue LED (left) – Wireless Radio enabled
Expansion
Integrated Compact Flash Type II (CF) and Secure Digital (SDIO) slot - Supports SD/MMC type standard, SDIO ready
Audio
Integrated microphone, receiver, speaker and one 3.5 mm stereo headphone jack, MP3 stereo (through headphone jack)
Design features
4 programmable application quick-launch buttons
5-way navigation button
Rechargeable/removable battery
Touch-sensitive display for stylus or fingertip
Voice record button
Microphone and speaker
Rubber sides for comfortable grip
Component Specifications
Feature
Type: Transflective TFT QVGA color with LED backlight with power save mode
Modes: Portrait and Landscape
Number of Colors: 64K color (65,536 colors) 16-bit
Touch Screen: Yes
Resolution (W x H): 240 x 320 pixels
Dot Pitch: 0.24 mm
Viewable Image Size: 3.5 in (89 mm)
HP iPAQ buttons
By default, the application buttons are set to launch the following applications when pressed.
  • Button 1 - Calendar
  • Button 2 - Contacts
  • Button 3 - Messaging (Inbox)
  • Button 4 - iTask
By default, the application buttons are set to launch the following applications when pressed and held.
  • Button 1 - Rotate Screen (Landscape/Portrait)
  • Button 2 - Launches HP Protect Tools
  • Button 3 - Launches the wireless tutorial the very first use. Afterwards, launches the iPAQ Wireless application.
  • Button 4 - Works with iTask to change tasks. If no programs are running then it does nothing. If several things are running then it switches between them each time the button is pressed and held.
  • Power Button - Turns Off/On backlighting
Physical Specifications
Feature
Dimensions
4.71 x 3.01 x .65 in (119.4 x 76.6 x 16.3 mm)
(5.8 oz) 164.4 g
Electrical Specifications
Feature
Battery
hx2700/hx2400 - Removable/rechargeable 1440 mAh lithium-lon
hx2100 - Removable/rechargeable 920 mAh lithium-lon
AC Power
AC Input: 100~240 Vac, 50/60 Hz
AC Input current: 0.3 A max
Output Voltage: 5Vdc (typical)
Output Current: 2A (typical)
Shipping Contents
Feature
Models
hx2750
hx2410
hx2110
In the Box
HP iPAQ hx2000 series Pocket PC, removable/rechargeable lithium-lon battery, AC adapter, charger adapter, stylus, protective plastic flip cover, Getting Started Guide, HP iPAQ Pocket PC Companion CD, and How Do I…? Guide
USB desktop synchronization cradle
USB synchronization cable
