HP Designjet EFI Designer Edition RIP - No Connection to Printer
Issue:
The EFI Designer Edition RIP is displaying the message no connection to printer.
The error messages displayed in the program window are preceded by the word "input," "color," "print" or "port" to indicate at which stage of processing the problem occurred.
Solution
Check that the printer is properly connected.
Then make sure that the printer is properly set up in EFI Designer Edition and in your operating system.
Cause
EFI Designer Edition is unable to send the print data to the printer.
