HP Designjet Printers - When Configuring the HP Jetdirect Card the Gateway Byte Reverts to a Different Setting than Was Originally Set
Issue:
This document is intended for HP Designjet printers that support HP Jetdirect card configuration through the printers front panel display.
When configuring the HP Jetdirect card (any internal HP Jetdirect card) through the front panel of the HP Designjet printer, you may find that the Gateway byte (GW Byte) reverts to a different setting (usually the IP address) once the settings have been saved and the printer is rebooted.
Solution
This issue generally occurs when the specified GW byte and Subnet Mask are conflicting. In this case, verify with network administrator that the Subnet Mask and GW byte values are accurate. If the values are not correct, update the incorrect values and try again.
