HP iPAQ Pocket PC h5100 and h5500 Series - How Do I Use Bluetooth to Connect to a Cell Phone?
You can establish a partnership between your HP iPAQ Pocket PC and your Bluetooth-equipped cell phone. Doing so allows you to connect to the Internet using your Bluetooth cell phone as a wireless access point.
Using your cell phone as a wireless access point will give you slower data speeds than other means of connecting to the Internet.
Wireless technology information is viewable by the outside world unless authorization (accepting/declining a pairing) and/or authentication (requiring a passkey) are enabled. It is highly recommended that you enable these security features on both your HP iPAQ Pocket PC and your cell phone as sensitive information can be retrieved from your Pocket PC and cell phone service can be stolen without your knowledge if an unauthorized user accesses your wireless devices.
For more information on enabling these security features on your Pocket PC, refer to Step 4 of How Do I Use Bluetooth to Transfer Files to Another Pocket PC, Computer, or Printer?Click here to view the document "How Do I Use Bluetooth to Transfer Files to Another Pocket PC, Computer, or Printer?" For more information on enabling these security features on your cell phone, refer to the documentation that came with your cell phone.
Pairing a Bluetooth cell phone with an HP iPAQ Pocket PC
To pair your Bluetooth cell phone and your HP iPAQ Pocket PC, do the following:
  1. From the Today screen, tap the Bluetooth icon ( ) in the lower-right corner, then tap Turn Bluetooth ON.
    Figure : Today screen
  2. Be sure your HP iPAQ Pocket PC is in discoverable and pairable mode by tapping the Bluetooth icon, Bluetooth Settings, then Accessibility tab.
    Check both the Allow other devices to connect checkbox and the Other devices can discover me checkbox, then tap OK.
    Figure : Bluetooth Accessibility screen
  3. Turn on the Bluetooth function on your cell phone. Refer to the instructions that came with your cell phone for more information.
  4. Tap the Bluetooth icon on your HP iPAQ Pocket PC again, then tap Bluetooth Manager, New, then Connect.
  5. Select Partner with a cell phone, then tap Next.
    Figure : Bluetooth Connection wizard
  6. Select your cell phone from the Phone selection list, then tap Next.
    If your cell phone is not listed, select Unknown, or phone not listed.
  7. Enable Bluetooth on your cell phone and pair the devices. Be sure your phone is in discoverable and pairable mode. Refer to the instructions that came with your cell phone for more information. Once the phone is both Discoverable and Pairable, tap Next on your HP iPAQ Pocket PC.
  8. Tap the Device box to select a cell phone.
  9. When the phone appears in the Bluetooth Browser, select it, then enter a passkey. If you do not already have a passkey, you can enter your own.
  10. Enter the same passkey into the cell phone when prompted by the phone.
  11. Tap Finish on your HP iPAQ Pocket PC. Your HP iPAQ Pocket PC and cell phone are now paired.
Creating an Internet connection with a Bluetooth cell phone and an HP iPAQ Pocket PC
To create an Internet connection using your Bluetooth cell phone and your HP iPAQ Pocket PC, do the following:
  1. Set up data account proxy information from your phone provider to connect to a General Packet Radio Service (GPRS) network. To find out how to connect to a GPRS network using your cell phone, contact your cell phone service provider.
  2. On your HP iPAQ Pocket PC, tap the Bluetooth icon, Bluetooth Manager, then My Shortcuts tab.
    Figure : Bluetooth Manager
  3. Tap and hold the Dial-up Networking connection created in the procedure above, then tap Connect.
  4. Select New Connection, then tap OK.
  5. Enter a name for the connection. Obtain your country code, area code, and phone number from your cell phone service provider. Enter the information in the appropriate boxes, then tap OK.
  6. Once a connection has been established, from the Today screen, tap Start, then Internet Explorer and begin using the Internet.
