    Fix Windows 10 Update Issues
HP Compaq Business Notebook nc6000 Series - Power Cord Requirements
Three-conductor power cord
The wide range input feature of the notebook permits it to operate from any line voltage from 100 to 120 or 220 to 240 volts AC.
The power cord included with the notebook meets the requirements for use in the country/region where the equipment is purchased.
Power cords for use in other countries/regions must meet the requirements of the country/region where the notebook is used. For more information on power cord requirements, contact an HP authorized reseller or service provider.
General requirements
The requirements listed below are applicable to all countries/regions:
  • The length of the power cord must be at least 1.5 meters (5.00 feet) and a maximum of 2.0 meters (6.50 feet).
  • All power cords must be approved by an acceptable accredited agency responsible for evaluation in the country/region where the power cord will be used.
  • The power cord must have a minimum current capacity of 10 amps and a nominal voltage rating of 125 or 250 volts AC, as required by each country's/region's power system.
  • The appliance coupler must meet the mechanical configuration of an EN 60 320/IEC 320 Standard Sheet C13 connector for mating with the appliance inlet on the back of the notebook.
Country/region-specific requirements
Country/region
Accredited Agency
Note
Australia
EANSW
The flexible cord must be <HAR> Type HO5VV-F, 3-conductor, 1.0 mm2 conductor size. Power cord fittings (appliance coupler and wall plug) must bear the certification mark of the agency responsible for evaluation in the country/region where it will be used.
Austria
OVE
The flexible cord must be <HAR> Type HO5VV-F, three-conductor, 1.0 mm2 conductor size. Power cord fittings (appliance coupler and wall plug) must bear the certification mark of the agency responsible for evaluation in the country/region where it will be used.
Belgium
CEBC
Canada
CSA
The flexible cord must be Type SPT-3 or equivalent, No. 18 AWG, 3-conductor. The wall plug must be a two-pole grounding type with a NEMA 5-15P (15 A, 125 V) or NEMA 6-15P (15 A, 250 V) configuration.
Denmark
DEMKO
Finland
FIMKO
France
UTE
Germany
VDE
Italy
IMQ
The flexible cord must be <HAR> Type HO5VV-F, three-conductor, 1.0 mm2 conductor size. Power cord fittings (appliance coupler and wall plug) must bear the certification mark of the agency responsible for evaluation in the country/reigon where it will be used.
Japan
METI
The appliance coupler, flexible cord, and wall plug must bear a "T" mark and registration number in accordance with the Japanese Dentori Law. The flexible cord must be Type VCT or VCTF, three-conductor, 1.00 mm2 conductor size. The wall plug must be a two-pole grounding type with a Japanese Industrial Standard C8303 (7 A, 125 V) configuration.
The Netherlands
KEMA
Norway
NEMKO
Sweden
SEMKO
Switzerland
SEV
United Kingdom
BSI
United States
UL
The flexible cord must be Type SPT-3 or equivalent, No. 18 AWG, three-conductor. The wall plug must be a two-pole grounding type with a NEMA 5-15P (15 A, 125 V) or NEMA 6-15P (15 A, 250 V) configuration.
