    We are upgrading our website
A 'Print Cartridge Cradle is Stuck' Error Message Displays for HP Deskjet 5100, 5650, and 5850 Printer Series
Issue
A 'Print Cartridge Cradle is Stuck' error message might display on the computer. The product also might have the following issues:
  • A paper jam
  • The product will not print
  • Printing stopped unexpectedly
  • The print cartridge cradle (carriage) is stuck on either side or in the middle of the printer
How to use the solutions in this document
A carriage jam can occur for several reasons, such as obstructions in the path of the carriage, a paper jam, or even issues with the product software.
To resolve the issue, try each solution in this document, and then use the steps in this section to print a self-test report to determine if the product hardware functions correctly. Once you have resolved the issue, and the product successfully prints a self-test report, there is no need to continue troubleshooting.
Print a self-test report
Follow these steps to print a self-test report.
  1. Load plain paper in the paper tray.
  2. Press the Power button () to turn on the product.
  3. Press and hold the Power button ().
  4. Press the Resume button () four times. The self-test page prints.
IMPORTANT: Try to print a self-test report after every solution even if the solution appears to resolve the issue.
Solution one: Turn the printer off and on again
Follow these steps to turn the product on, and then off again, to reset the print mechanism.
  1. Press the Power button () to turn the product off.
  2. Wait 15 seconds.
  3. Press the Power button () to turn the product on.
  4. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
  • If these steps resolved the issue, and the self-test report prints, there is no need to continue troubleshooting. Try printing again.
  • If the issue persists, continue with the next solution.
  • If the self-test report does not print, continue with the next solution.
Solution two: Clear any paper jams
Jammed paper can cause the carriage to stall. Follow these steps to clear any jammed paper.
Step one: Remove any loose paper from the tray
Remove any loose paper from the paper tray.
Do not remove jammed paper at this stage.
Step two: Clear the paper jam from the back of the printer
Use the following steps to clear a paper jam from the back of the product. If the two-sided printing accessory (duplexer) is not installed on the back of the product, skip to the next section to clear the jam through the rear access door.
Never remove jammed paper from the front or inside of the HP product if you can remove it from the back of the product. Pulling paper from inside the front cover can cause mechanical damage to the HP product.
Clear the jam from the two-sided printing accessory (duplexer)
  1. Press the Power button () to turn off the product.
  2. Disconnect the USB cable from the back of the product.
  3. Disconnect the power cord from the back of the product.
  4. On the back of the HP product, press and hold the buttons on each side of the duplexer, and then pull it toward you to remove it.
    Figure : Remove the duplexer
    Illustration of removing the duplexer
  5. Carefully pull any jammed paper out of the rollers located inside the product.
    If the paper tears when removing it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the device, more paper jams are likely to occur.
  6. On the duplexer, press the button on the top, and then lower the access door.
    Figure : Lower the access cover on the duplexer
    Illustration of lowering the access door on the duplexer
  7. Remove any jammed paper from inside the duplexer.
  8. Close the access cover on the duplexer.
  9. Reattach the duplexer to the back of the product, and make sure both sides snap into place.
    Figure : Reattach the duplexer
    Illustration of reattaching the duplexer
Clear the jam from the rear access door
  4. On the back of the HP product, push the two latch handles on the rear access door toward each other, and then pull the door toward you to remove it.
    Figure : Remove the rear access door
    Illustration of removing the rear access door
  5. Carefully pull any jammed paper out of the rollers located inside the back of the product.
  6. Reattach the rear access door. Make sure that it snaps into place.
    Figure : Reattach the rear access door
    Illustration of reattaching the rear access door
Step three: Clear the paper jam from the front of the printer
If you cannot remove the paper jam from the back of the product, follow these steps to remove the paper jam from the front.
IMPORTANT: Remove the paper very carefully. If the paper tears, part of it might remain inside the paper path and damage the product. Carefully remove all traces of paper that you can find.
  1. Reconnect the power cord to the back of the product.
  3. Open the top cover on the HP product. The carriage might try to move into the access area. If so, allow the carriage to move to that position.
  4. Without turning off the product, disconnect the power cord from the back of the product.
    You must disconnect the power cord to move parts by hand without the risk of an electrical shock.
  5. Unplug the power cord from the wall outlet.
  6. Look inside the product, and then check for any paper or object that might be restricting the carriage.
  7. Reach inside the product through the paper output tray, and then manually move the carriage.
    • If the carriage is stuck on the right side of the product, move the carriage to the left side of the product.
    • If the carriage is stuck on the left side of the product, move the carriage to the right side of the product.
    • If the carriage is stuck in the middle of the product, move the carriage to the right side of the product.
  8. Remove any loose paper or obstructions found.
  9. Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right.
  10. Close the top cover.
  11. Reconnect the power cord to the back of the product, and to the wall outlet.
  12. Press the Power button () to turn on the product.
Step four: Print a self-test report
  • If these steps resolved the issue, and the test page prints, there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again.
  • If the test page does not print, continue with the next solution.
Solution three: Make sure that the cartridges are installed correctly
Improper placement or incorrect installation of the cartridges might cause the carriage stall error. Follow these steps to remove and then reinstall the cartridges.
Step one: Remove the cartridges
  1. Press the Power button () to turn on the product.
  2. Open the top cover. The carriage might try to move into the access area. Wait until the carriage is idle and silent before proceeding.
  3. Raise each of the cartridge latches.
    Figure : Raise the cartridge latches
    Illustration of raising the cartridge latch
  4. Slide the cartridge out of its slot and pull it toward you to remove it.
    Figure : Remove the cartridge
    Illustration of removing the cartridge
    Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
    Figure : Do not touch the contacts or ink nozzles
  5. Repeat the previous step to remove the other cartridge.
  6. Check for obstructions under and around the carriage. Remove any obstructions.
Step two: Reinstall the cartridges
  1. Hold the cartridge so that the nozzles face down and the contacts face toward the carriage.
  2. Slide the cartridge into the slot until it snaps into place.
    Figure : Reinstall the cartridge
    Illustration of reinstalling the cartridge
  3. Close the cartridge latch. Press the cartridge latch down until it snaps firmly into place.
  4. Repeat these steps for the other cartridge.
  5. Close the top cover.
Step three: Print a self-test report
Solution four: Plug the product directly into a wall outlet
Plug the product directly into a wall outlet to make sure the power source is functioning correctly.
  1. Disconnect the power cord from the back of the product.
  2. Disconnect the power cord from any power strip or surge suppressor, and then plug it directly into the wall outlet.
  3. Reconnect the power cord to the back of the product.
  4. Press the Power button () to turn on the product.
  5. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
    If the product prints when plugged directly into a wall outlet, the power strip or surge suppressor might not be allowing enough voltage to reach the product.
Solution five: Perform a power reset
Follow these steps to reset the product.
  2. Disconnect the power cord from the back of the product.
  3. Disconnect the power cord from the electrical outlet.
  4. Wait 15 seconds.
  5. Reconnect the power cord to the electrical outlet.
  6. Reconnect the power cord to the back of the product.
  7. Press the Power button () to turn on the product.
  8. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
  • If the test page prints successfully, but you experience a different issue with your printer, go to HP Product Support Home Page, and then search for another document that relates to the issue you are experiencing.
    If the page displays in the wrong region or language, click the Region - Language link in the upper right corner of your browser. Then you can select the correct region and language.
  • If the product does not print a test page, there is an issue with the product hardware. Continue to the next solution.
Solution six: Service the product
