Compaq iPAQ H3000 Series - System Views
Front panel components
    Figure : Front panel components
  1. Stylus - Allows you to tap or write on the screen. Push the stylus release button (w) to release it from the compartment.
  2. Power Button - Powers the iPAQ H3000. Press and release the button to turn on or off your iPAQ H3000. Press and hold the button for one second to toggle on or off the backlight.
  3. Alarm/Charge Light - Serves as both a battery charge indicator and a visual alarm indicator. Flashing green: Notification alarm signal. Flashing amber: Battery is charging. Solid amber: Battery is fully charged.
  4. Light Sensor - Detects the ambient light level so that the backlight level adjusts to suit the environment.
  5. Speaker - Sounds alarms and plays back sound recordings.
  6. iPAQ Navigator/ Action Button - Allows you to scroll through a list (similar to pressing the arrow keys on a keyboard). In the list view of a program, you can use your iPAQ Navigator to scroll to the item you want to view. Can also be used as game buttons within a game application. The center of the button can be used as an Action button to open a selected item.
  7. Application Buttons - Allow quick access to four applications. By default, the applications are Calendar, Contacts, QMenu, and QStart. You can change the functions of the application buttons to open different applications.
  8. Record Button Activates the record function in Notes. For more information, see “Notes” in Chapter 4. You can change the function of the Record button so that it opens a different application.
  9. Microphone - Allows you to record voice messages
  10. Headphone Jack Lets you connect standard headphones.
  11. Infrared Port - Enables you to exchange data with other Windows- powered devices. The infrared port can transmit at speeds up to 115.2Kb per second.
  12. Stylus Release Button - Lets you eject the stylus from its compartment.
Bottom edge components
    Figure : Bottom edge components
  1. Communications Port - Connects your iPAQ H3000 to the cradle (or to an optional USB or serial cable).
  2. Reset Button - Lets you reset your iPAQ H3000.
  3. On/Off Switch - Allows you to clear all data, and reset your system if you have forgotten your password. Clearing memory deletes all data and restores your iPAQ H3000 to its default settings.
  4. DC Jack - Allows you to connect to external power with the supplied AC adapter.
  5. iPAQ Expansion Pack Connector Connects to the connector of an (optional) iPAQ Expansion Pack.
Country: Flag Serbia
