Compaq CompactFlash Card Expansion Pack Plus - Features and Specifications
Features and specifications
This document lists detailed features and specifications of the CompactFlash Card Expansion Pack Plus.
Figure : CompactFlash Card Expansion Pack Plus
Feature
Specification
Compatibility
All Compaq iPAQ H3xxx handheld units
Operating system support
Microsoft Pocket PC, Pocket PC 2002 or later
Open slots
Type I or Type II CF card slot
Battery technology
Lithium-Ion Polymer battery
Battery capacity
920 milliamp hours (mAh)
Battery charge time
Charging in Expansion Pack Plus Approximately 2 hours
Using Battery Charger Approximately 2 hours (2x Slim Battery or Slim + Extended Battery)
Using Battery Charger Approximately 3 hours (2x Extended Battery)
Dimensions
3.5 x 5.2 x 1.4 inches (88.9 x 132.1 x 35.6 mm)
Size
Adds only 6.8 mm (0.27 inch) to the Compaq iPAQ Pocket PC with Protective battery cover
Adds only 11.7 mm (0.46 inch) to the Compaq iPAQ Pocket PC with included slim battery
Adds only 16.6 mm (0.65 inch) to the Compaq iPAQ Pocket PC with optional extended battery
4.5 oz (129 g) with included slim battery
5.5 oz (157 g) with optional extended battery
Operating temperature
14 to 104 degrees F (–10 to 40 degrees C)
Storage temperature
–22 to 140 degrees F (–30 to 60 degrees C)
Operational humidity
10 to 90% at 77 degrees F (25 degrees C)
Kit contents
CF Card Expansion Pack Plus
CD-ROM (contains Compaq iPAQ Pocket PC H3600 series ROM upgrade, Compaq iPAQ Pocket PC H3800 series Device Manager upgrade, and a user guide)
Battery cover (for use when no external battery is installed)
Worldwide warranty card
Worldwide service telephone list
Compaq Getting Started Guide
Supplies main power to the Compaq iPAQ
Yes, always
Supplies power to CF card
Never
Trickle charge
Yes, when external battery voltage is greater than main battery voltage
Extended battery required
No, optional
Hot swappable
Yes
Link to Warranty Information
Click here for additional information regarding worldwide limited warranty and technical support available at: http://h10010.www1.hp.com/wwpc/pscmisc/vac/us/en/sm/pocketpc/handhelds_warranty.
Country: Flag Serbia
