HP iPAQ GPS Nav System - What HP iPAQ Pocket PC Model Are Supported with the HP iPAQ Navigation System?
Issue:
What HP iPAQ Pocket PC models are supported with the HP iPAQ Navigation System?
Solution
The HP iPAQ Navigation System is designed to run on your Bluetooth enabled HP iPAQ Pocket PC. The following Bluetooth enabled HP iPAQ Pocket PC models are supported:
  • HP iPAQ Pocket PC h2210 series
  • HP iPAQ Pocket PC h4150 series
  • HP iPAQ Pocket PC h5150 series
  • HP iPAQ Pocket PC h5450 series
  • HP iPAQ Pocket PC h5550 series
Summary
Click here to access support information about the iPAQ Navigation System on the Web. Alternatively, technical support for your iPAQ Navigation System is available by calling 1-866-4HP-NAV1 (1-866-447-6281) between 8 a.m. and 8 p.m. (EST) Monday through Friday.
