HP iPAQ Pocket PC h4100 and h4300 Series - Routine Care
To keep your iPAQ Pocket PC in good condition and working properly, follow these guidelines:
  • Keep your Pocket PC away from excessive moisture and temperature extremes.
  • Do not expose your Pocket PC to liquids or precipitation.
  • Do not place anything on top of your Pocket PC to prevent damage to the screen.
  • Clean your Pocket PC by wiping the screen and the exterior with a soft, damp cloth lightly moistened only with water.
  • Avoid exposing your Pocket PC to direct sunlight or strong ultraviolet light for extended periods of time.
  • Avoid scratching the surface of the screen and banging it against hard objects.
  • Use only the stylus that comes with your Pocket PC or an approved replacement on the screen to prevent scratching it.
To reduce the risk of damage to the internal components, do not spray liquid directly on the screen or allow excess liquid to drip inside your iPAQ Pocket PC. Using soap or other cleaning products on the screen may discolor the finish and damage it.
