HP Photosmart 245, 7660, 7755, 7760, and 7960 Printers - Restoring the Factory Settings
It is possible that certain settings on the HP Photosmart 7660, 7755, 7760, and 7960 printers can affect image quality. The settings can be set back to default using the front panel on the printer.
Restoring Default settings on the HP Photosmart 7660 printer
  1. Press the menu Left Arrow or Right Arrows until Reset All Menu Settings is visible in the front display.
  2. Press the OK button. A message will appear on the display confirming that all menu preferences have been reset.
Restoring Default settings on the HP Photosmart 7755, 7760, 7960, and 245 printers
  1. Press the Menu button on the front panel of the printer.
  2. Select Preferences using the Up Arrow and Down Arrow on the front panel, and click the OK button.
  3. Select the Restore Defaults button and press OK. A message will appear on the display confirming that all menu preferences have been reset.
