All hardware errors begin with a 'C.' Similar errors begin with a 'E' or a '9.' These can be treated the same. The '??' field is for 'more error info.' It is additional information about the error. The error code is the 'xx' field.
- ${title}
- ${title}
- ${title}
- ${title}
HP Business Inkjet 1000 and 1100 Printer Series - Firmware Error Codes
Generic errors (all can return) (C***00xx) file macro_include/generic_errors.h
0x7F Firm table mismatch
0x80 Firm table name too long
0x81 Bad provided IFC index
0x82 Bad required IFC index
0x83 Bad message send
0x84 Unknown command
0x85 Unexpected command
0x86 unimplemented command
0x87 Out of room
0x88 Parameter out of range
0x89 Parameter too small
0x8A Parameter too large
0x8B Parameter mismatch
0x8C Unexpected value
0x8D Unexpected NULL pointer
0x8E Expected NULL pointer
0x8F Less than zero
0x90 Divide by zero
Stack Check (C00100xx) file util/src/util_stack_check.h
XX indicates which task has a stack overrun.
Mechanism (C00200xx) file mech/src/mech_errors.h
0x01 Media jam
0x02 Paper stall
0x03 Carriage stall
0x04 <0 timer unit
0x05 Unexpected timer unit
0x06 Unexpected timer state
0x07 Not modifier timer
0x08 Unknown timer command
0x09 Timers not active
0x0A Bad startup
0x0B Unknown timer units
0x0C In job start
0x0D Out of job end
0x0E Service stall
0x2F No carriage PCA
0x30 Carriage board off
0x4x Bad calibration.
Pen (C00300xx) file pen/src/pen_errors.h
0x00-0x0F Pen under temperature (K:08, C:04, M:02, Y:01)
0x10-0x1F Pen over temperature (K:08, C:04, M:02, Y:01)
Carriage (C00400xx) file carriage/src/carriage_errors.h
0x01 Shutdown while moving.
Paper (C00500xx) file none
Not used anymore
Service Station (C00600xx) file dc_service/src/dc_service_errors.h
Underware (C00700xx)
Uses generic errors (0x7F-0xFF)
Processor (C00800xx)
Not used anymore
Sweep Manager (C00900xx)
0x00 Invalid nozzle
0x01 no data present
0x02 not in direct drive
0x03 invalid carriage speed
0x04 invalid direction
0x05 data buffer full
0x06 negative move
0x07 invalid resolution
0x08 too many sweeps
0x09 no data found
0x0A invalid carriage ramp speed
0x0B invalid firing resolution
0x0C mismatch KCMY position.
Reports (C00A00xx)
PCL (C00B00xx)
0x01 ERRbad_symbolset
0x02 ERRbad_metrics
0x03 ERRno_ss_entity
0x04 ERRmem_alloc
0x08 FONT_SELECTMODE_ERROR
0x09 FONT_FORMAT_ERROR
0x0a FMTR_CANNOT_ALLOC_MEM
0x10 PCL_ERROR
0x11 PCL_INVALID_ORIENTATION
0x12 PCL_INVALID_POSITION
0x13 PCL_INVALID_CHARACTER
0x14 PCL_UNDERLINE_ERROR
0x15 PMGR_ERROR
0x1a DL_BAD_OPCODE
0x1b DL_READ_BUFF_ERROR
0x1c DL_BAD_FMGR_CALL
0x1d DL_BAD_BYTE_COUNT
0x1e DL_BAD_ORIENTATION
0x1f DL_BAD_SWATH_POS
0x20 PMGR_NO_PAGE_OPEN
0x21 PMGR_NO_MEM
0x22 PMGR_ED_PAGE_ERROR
0x23 PMGR_NO_RENDER_RES
0x24 PMGR_BAD_RENDER_RES
0x29 IO_NO_MEMORY
0x2a IO_WD_CREATE_FAIL
0x2b IO_GIVE_SEM_FAIL
0x2c IO_UNSUPPORTED_SOCKET
0x30 SYS_PARAMETER_ERR
0x40 ED_INVALID_PEN
0x50 EU_DLB_BIT_SCRATCH_BUFFER_TOO_SMALL
0x51 EU_TRIPLE_BIT_SCRATCH_BUFFER_TOO_SMALL
0x52 EU_ED_PLANE_ALLOC_ERROR
0x53 EU_RASTER_PLANE_ERROR
0x54 EU_RASTER_ROW_ERROR
0x7f NONSPEC_ERROR
Device Info (C00C00xx)
0x01 Reserved character
P1284 (C00D00xx)
Ink Supply (C00E00xx)
Spot Cal Page (C00F00xx)
MICCI (C010??xx) )
0x??01 FW usage error (RB) ?? indicates ID & register.
0x??02 FW usage error (WB) ?? indicates ID & register.
0x??03 FW usage error (VRB) ?? indicates ID & register.
0x??04 FW usage error (VWB) ?? indicates ID & register.
0x??05 FW usage error (RW) ?? indicates ID & register.
0x??06 FW usage error (WW) ?? indicates ID & register.
0x??08 FW usage error (RB) ?? indicates ID & register.
0x??09 FW usage error (WB) ?? indicates ID & register.
0x??0A FW usage error (VRB ?? indicates ID & register.
0x??0B FW usage error (VWB) ?? indicates ID & register.
0x??0C FW usage error (RW) ?? indicates ID & register.
0x??0D FW usage error (WW) ?? indicates ID & register.
0x??0E FW usage error (MLACHW) ?? indicates ID & register.
0x11 DEVICE_WENT_BAD. Common w/ broken trailing cable.
0x12 MICCI device not responding (formerly 0x40 or 0x10).
(11 & 12 Due to the loss of 32V or a broken trailing cable. )
0x13 MICCI protocol error during a spot sweep
0x??20 Stuck bit in Synergy. Register is ??. +0x40 for verified read.
0x??21 Stuck bit in Endeavour. Register is ??. +0x40 for verified read.
0x??22 ERROR_LIB__MICCI_STUCK_BIT_ID_2
0x??23 ERROR_LIB__MICCI_STUCK_BIT_ID_3
0x??24 ERROR_LIB__MICCI_STUCK_BIT_ID_4
0x??25 ERROR_LIB__MICCI_STUCK_BIT_ID_5
0x??26 ERROR_LIB__MICCI_STUCK_BIT_ID_6
0x??27 ERROR_LIB__MICCI_STUCK_BIT_ID_7
0x7F - 0xFF reserved for generic firmware errors.
Endeavour (C011??xx)
0x01 Unsupported device.
0x02 Bad a2d reading.
0x03 Endeavour A2D not ready.
Synergy (C012??xx)
0x01 Unsupported devices (revision too old).
0x??02: Versions <= LP5.12
0x0002: All synergy A2D errors
Versions LP5.13-LP5.15
0xC002: Not ready at start - Go & done bits set
0x8002: Not ready at start - Go bit set
0x4002: Not ready at start - Done bit set
0x2002: Conversion wouldn't start (status=0)
0x0C02: Not Done - Go & done bits set
0x0802: Not Done - Go bit set (Conversion slow?)
0x0402: Not Done - Done bit set
Version 5.16
0x??04+ Synergy A2D NOT STARTED error (also 5, 6 & 7)
0x??08+ Synergy A2D NOT DONE error (also 9, A & B) (status=0)
0x??0C+ Synergy A2D NOT IDLE error (also D, E & F) (not converting?)
0x80xx Synergy protocol errors have happened.
0x40xx Synergy verified read errors have happened.
0x20xx Synergy verified write errors have happened.
0x10xx Synergy slow verified read errors have happened.
0x0?xx A2D channel being read.
??: 0x??02 Transmit bit set.
0x??01 Done bit set.
0x??1x 'Slow' verfied read error. (x= Synergy register, ??= 1st XOR 2nd)
Won't be reported the first time, which is ok.
0x??20 Synergy lost 32V - detected in a2d routine. ?? = voltage.
Carriage PCA Asserts (C013??xx) file cbio/src/cbio_errors.h
note:The '??' field is for 'more error info.' Its contents are listed with each entry.
0x00 ( 0) is Ok. see pen_fault.cb_result. Also for 2nd assert in Network debugging
0x01 ( 1) CB_32V_STUCK_ON (Fet in Main logic PCA is shorted)
0x02 ( 2) Black pen regulator unpause error
0x03 ( 3) Color pen regulator unpause error
0x04 ( 4) CB_5V_TOO_LOW to Carriage PCA. (?? is the A2D value.)
0x05 ( 5) CB_5V_TOO_HIGH to Carriage PCA. (?? is the A2D value.)
0x06 ( 6) CB_12V_TOO_LOW to Carriage PCA. (?? is the A2D value.)
0x07 ( 7) CB_12V_TOO_HIGH to Carriage PCA. (?? is the A2D value.)
0x08 ( 8) CB_32V_TOO_LOW to Carriage PCA. (?? is the A2D value.)
0x09 ( 9) CB_32V_TOO_HIGH to Carriage PCA. (?? is the A2D value.)
0x0A ( 10) CB_VPP1_TOO_LOW (?? Is the reading in volts)
0x0B ( 11) CB_VPP1_TOO_HIGH (?? Is the reading in volts)
0x0C ( 12) CB_VPP2_TOO_LOW (?? Is the reading in volts)
0x0D ( 13) CB_VPP2_TOO_HIGH (?? Is the reading in volts)
0x0E ( 14) Endeavour A2D not ready error.
0x0F ( 15) CB_NO_MICCI_DEVICES (probably no carriage PCA/ broken trailing cable)
0x10 ( 16) CB_SYNERGY_MISSING but Endeavour was found (bad CB)
0x11 ( 17) CB_SYNERGY_ST_ERROR (bad CB)
0x12 ( 18) CB_SYNERGY_A2D_BAD (bad CB)
0x13 ( 19) +12V regulator unpause error (??=regulator status)
0x14 ( 20) Powered off during a pen health test (?)
0x15 ( 21) CB_SYNERGY_MISSING_CLOCK (??: see ERR_ID below)
0x16 ( 22) Synergy was reset (detected after a measurement error).
0x17 ( 23) Shorted Spot sensor (5V to gnd short), causing a synergy error.
0x18 ( 24) CB_SYNERGY_12V_LOST Synergy shut down. (??=1 if retesting)
0x19 ( 25) Black Vpp2 regulator lost (shut down) (??: see ERR_ID below)
0x1A ( 26) Color Vpp1 regulator lost (shut down) (??: see ERR_ID below)
0x1B ( 27) Synergy 12V regulator error (??=regulator status)
0x1C ( 28) Black Vpp2 regulator error (??=regulator status)
0x1D ( 29) Color Vpp1 regulator error (??=regulator status)
0x1E ( 30) Black Vpp calibration error (?? = K Vpp voltage - need > 5V)
0x1F ( 31) Color Vpp calibration error (?? = CMY Vpp voltage - need > 5V)
0x20 ( 32) CB_ENDEAVOUR_MISSING but Synergy was found (bad CB)
0x21 ( 33) CB_ENDEAVOUR_ST_ERROR (bad CB)
0x22 ( 34) CB_ENDEAVOUR_A2D_BAD (bad CB) (?? = a2d reading)
0x23 ( 35) CB_PENS_NOT_POWERED when a routine thought they should be
0x24 ( 36) CB_SPOT_LED_BAD Spot LED is backwards, sensor missing (?? a2d)
0x25 ( 37) CB_DIMPLE_FLEX_BAD_PWR CB hardware error (?? a2d)
0x26 ( 38) CB_DIMPLE_FLEX_BAD_HW CB hardware error (?? a2d)
0x27 ( 39) CB_DIMPLE_FLEX_UNSEATED (check installation) (?? a2d)
0x28 ( 40) CB_DIMPLE_FLEX_MISSING (check installation) (?? a2d)
0x29 ( 41) CBIO asserted after another assert (BOGUS).
0x2A ( 42) CB_VPP_K_CAL_LOW_ERR (?? a2d)
0x2B ( 43) CB_VPP_CMY_CAL_LOW_ERR (?? a2d)
0x2C ( 44) CB_VPP_K_CAL_HIGH_ERR (?? a2d)
0x2D ( 45) CB_VPP_CMY_CAL_HIGH_ERR (?? a2d)
0x2E ( 46) CB_SYNERGY_LOST_12V Synergy shutdown. (not sclk or OT)(??: ERR_ID)
0x2F ( 47) 32V too low when Synergy was found to be reset (??=a2d)
0x30 (48) Black +5V on when it should be off (??: a2d)
0x31 (49) Cyan +5V on when it should be off (??: a2d)
0x32 (50) Magenta +5V on when it should be off (??: a2d)
0x33 (51) Yellow +5V on when it should be off (??: a2d)
0x34 (52) Black +12V on when it should be off (??: a2d)
0x35 (53) Cyan +12V on when it should be off (??: a2d)
0x36 (54) Magenta +12V on when it should be off (??: a2d)
0x37 (55) Yellow +12V on when it should be off (??: a2d)
0x38 (56) CB_NO_ACUMEN_PULLUP (bad CB or a device is grounding the data line)
0x39 (57) CB_NO_ACUMEN_DRIVE (bad CB) (??: a2d)
0x3A (58) Acumen HW8 error (bad Endeavour?) (bad CB)
0x3B (59) Acumen HW9 error (bad Endeavour - won't do multibyte xfer) (bad CB)
0x3C (60) Acumen multibyte read error (bad CB) (mid line test only)
0x3D (61) Acumen Bus fight on all devices (mid line test only)
0x3E (62) Acumen Bus start bit error on all devices (mid line test only)
0x3F (63) Acumen Bus stop bit error on all devices (mid line test only)
0x40 (64) Pen HW Ownership Take error (?? = old/new id)
0x41 (65) Pen HW Ownership Give error (?? = old/new id)
0x42 (66) Endeavour over temperature shutdown event
0x43 (67) Synergy over temperature shutdown event (?? See ERR_ID below)
0x44 (68) 5V too low to Carriage PCA during a retest. (?? is the A2D value.)
0x45 (69) 12V too low to Carriage PCA during a retest. (?? is the A2D value.)
0x46 (70) Vpp2 (black) voltage too high when it should be off - (?? Volts)
0x47 (71) Vpp1 (color) voltage too high when it should be off - (?? Volts)
0x48 (72) Vpp2 (black) failed droop test (?? 0 or resistance/10)
0x49 (73) Vpp1 (color) failed droop test (?? 0 or resistance/10)
0x4A (74) Can't set a pen voltage trim register in Synergy (?? 0:K, 1:CMY)
0x4B (75) Can't turn off Vpp2 (black pen regulator) (?? Trim reg)
0x4C (76) Can't turn off Vpp1 (color pen regulator) (?? Trim reg)
0x4D (77) Can't turn off the 12V regulator (?? Status reg)
0x4E (78)
0x4F (79)
0x50 (80) Obsolete Endeavour ASIC on the carriage PCA.
0x51 (80) Obsolete Synergy ASIC on the carriage PCA.
0x70 (112) Endeavour Rcal init error (?? = a2d cnts (want 73-192))
0x71 (113) Endeavour 5V null error (?? = a2d cnts (want 48-134))
0x72 (114) Endeavour 5V 0mA error (?? = pen id (0-3))
0x73 (115) Endeavour 5V 10mA error (?? = pen id (0-3))
0x74 (116) Endeavour 12V null error (?? = a2d cnts (want 48-134))
0x75 (117) Endeavour 12V 0mA error (?? = pen id (0-3))
0x76 (118) Endeavour 12V 10mA error (?? = pen id (0-3))
0x77 (119) Pen Safety Watchdog (?? = last id, current id)
0x78 (120) Endeavour Rcal now error (?? = a2d cnts (want 73-192))
0x79 (121) Pause Error{0x7B and 0x7C}(?? = synergy error flags)
0x7A (122) Verification bad pen trap (?? = pen id)
0x7B (123) Unpause K unstable data (?? = 1st XOR 2nd)
0x7C (124) Unpause CMY unstable data (?? = 1st XOR 2nd)
0x7D (125) Watchdog while in print sweep (??= sec/10) (temporary)
0x7E (126) Watchdog error while testing (??= reference id) (temporary)
ERR_ID:
Field used to indicate the calling function for some CBIO errors.
While measuring the black pen voltage
While measuring the color pen voltage
After the 12v Regulator quit
While turning on the 12V regulator
While turning on the black pen regulator
while turning on the color pen regulator
While un-pausing the 12V regulator
While un-pausing the black pen regulator
While un-pausing the color pen regulator
While powering up the carriage pca
While setting a pen voltage
While performing an 'unpause'
Error prior to a cbio watchdog timeout.
While Pausing the black pen regulator
While Pausing the color pen regulator
When 12V was lost during a digital pen test
Pen & Supply (C0id00xx)
Id:
14: Black Pen
15: Cyan Pen
16: Magenta Pen
17: Yellow Pen
1B: Black Supply
1C: Color Supply
note:The 'xx' error codes are available via a 76 tap test when a pen problem exists. Last Cyclone Acumen failure codes are available (in HEX) on a 15 tap page in field 55.
0x00 No Short Cyclone Acumen
0x01 5V to pen under voltage (42 - 0x2A)
0x02 5V to pen over voltage (43 - 0x2B)
0x03 5V to pen measured low (42 - 0x2A)
0x04 5V to pen measured high (43 - 0x2B)
0x05 5V to pen measured over current (42 - 0x2A)
0x06 12V to pen under voltage (44 - 0x2C)
0x07 12V to pen over voltage (45 - 0x2D)
0x08 12V to pen measured low (44 - 0x2C)
0x09 12V to pen measured high (45 - 0X2D)
0x0A 12V to pen measured over current (44 - 0x2C)
0x0B Vpp measured over current (40 - 0x28)
0x0C Vpp measured over current @ pon (40 - 0x28)
0x0D Vpp measured over current @ test (40 - 0x28)
0x0E Vpp measured over voltage (41 - 0x29)
0x0F Digital test sez 'missing' (50 - 0x32)
0x10 Faked Digital pen error
0x11 Faked 5V to pen error
0x12 Faked 12V to pen error
0x13 Faked Vpp over current error
0x18 Internal pen 'too hot' flag (47 - 0x2F)
0x19 Not rev 3.0 silicon
0x1A Both Edata & Odata are bad
0x1B Garbled #1 (lumped w/digital errors) (46 - 0x36)
0x1C Garbled #2 (temporary?) (55 - 0x37)
0x1D Garbled #3 (temporary?) (56 - 0x38)
0x1E Garbled #4 (temporary?) (57 - 0x39)
0x1F Garbled #5 (temporary?) (58 - 0x3A)
Digital pen line tests
0x20 Initial bad CSDATA communication (54 - 0x36)
0x21 CSDATA garbled after being good (pre 5.17) (46 - 0x2E)
0x22 CS_Data echo failed (46 - 0x2E)
0x23 bad initial address sequencer (46 - 0x2E)
0x24 The address sequencer wasn't incremented (46 - 0x2E)
0x25 The address sequencer wasn't reset atfter (46 - 0x2E)
0x26 Data not received correctly in the pen regs (46 - 0x2E)
0x27 Data in the pen regs not cleared by a reset (46 - 0x2E)
0x28 Returned data =0 on initial communication (53 - 0x35)
0x29 Odata is bad
0x2A Edata is bad
0x2B Fire bad
0x2C 5V shorted to Vpp (52 - 0x34)
0x2D 12V shorted to Vpp (51 - 0x33)
0x2E 12V shorted to a signal line (48 - 0x30)
0x2F Vpp shorted to a signal line (49 - 0x31)
0x31 Pen Health detects an ink short warning
0x34 Pen component error code in ?? field.
0x6x Temporary CBIO detects an acumen problem (see lib_acumen.h).
Pen Component Errors (C0idxx34)
id:
14: Black Pen
15: Cyan Pen
16: Magenta Pen
17: Yellow Pen
note:This error code is only available after via a 76 tap test when the pen icon is flashing.
0x00 PFC_NO_ERROR
0x01 PFC_INK_LEAK
0x02 PFC_BAD_COLOR
0x03 PFC_0_DTSR
0x04 PFC_0_DROP_VOLUME
0x05 PFC_ACUMEN_BAD_TOKEN
0x06 PFC_ACUMEN_BAD_WRITE_PROT
0x07 PFC_BAD_MODEL_NUMBER
0x08 PFC_BAD_FAMILY_ID
0x09 PFC_FAILED_TTOV
0x0A PFC_VPP_SHORT
0x0B PFC_VPP_OVER_VOLTAGE
0x0C PFC_5_VOLT_SUPPLY_SHORT
0x0D PFC_5_VOLT_OVER_VOLTAGE
0x0E PFC_12_VOLT_SUPPLY_SHORT
0x0F PFC_12_VOLT_OVER_VOLTAGE
0x12 PFC_PEN_TEMP_ABOVE_MAX_LIMIT
0x13 PFC_PEN_TEMP_BELOW_MIN_LIMIT
0x17 PFC_PEN_TEMP_ABOVE_CONTROL_LIMIT
0x18 PFC_PEN_TEMP_BELOW_CONTROL_LIMIT
0x20 PFC_SILICON_OVER_TEMP
0x21 PFC_DIGITAL_TEST_FAILURE
0x23 PFC_NON_APPROVED_HP_OEM
0x24 PFC_BAD_MFG_WEEK
0x25 PFC_DOG_FAILURE
0x26 PFC_IDS_FAILURE
0x27 PFC_12V_TO_SIGNAL
0x28 PFC_VPP_TO_SIGNAL
0x29 PFC_SILICON_MISSING
0x2a PFC_12V_TO_VPP
0x2b PFC_5V_TO_VPP
0x2c PFC_NO_PEN_IO
0x2d PFC_CSDATA_GARBLED
0x2e PFC_DIGITAL_TEST_FAILURE_2
0x2f PFC_DIGITAL_TEST_FAILURE_3
0x30 PFC_DIGITAL_TEST_FAILURE_4
0x31 PFC_DIGITAL_TEST_FAILURE_5
Acumen Component (C01800xx)
0x10 Bad chip tag.
0x11 Bad Token Area.
0x12 Bad Write protect area.
0x13 Bad chip size.
0x14 Bad Parity
0x15 Bad Serial Number
(indicates the pen/ink has been swapped from under us)
HW_REGS Component (C01900xx)
0x04-0x0F remaps processor faults.
Real Time Clock (C01A??xx)
0x??00 Seconds failed. ?? is the reported value.
0x??01 Minutes failed. ?? is the reported value.
0x??02 Hours failed. ?? is the reported value.
0x??03 Day failed. ?? is the reported value.
0x??04 Date failed. ?? is the reported value.
0x??05 Month failed. ?? is the reported value.
0x??06 Year failed. ?? is the reported value.
SB Component (C0200xx)
Pen/Carriage PCA debugging hints
1) "cbio.cb_power 5;" will turn the carriage PCA power on and test the pens. It will not assert, but returns an error code in the format: "KCMYwwxx" where K,C,M & Y is the pen status, ww is extra bits (currently warm warnings from synergy and endeavour) and 'xx' is the error code listed for C01300xx above. The pens will be tested for shorts continuously.
Pen errors are:
0x00 pen is ok
0x01 pen is ok, but indicates an internal ink short.
0x02 pen is missing (acumen usable).
0x03 pen has been disabled due to another color pen being bad (acumen usable).
0x04 pen is bad (acumen usable)
0x05 pen is bad, and acumen is unusable.
0x06 one of the color pens is bad
0x07 unknown status
A 76 tap test will assert the first pen error available (order is K, C, M, then Y).
A 77 tap test will test for shorts continuously, and report a failure on the LCL panel.
Trailing Cable Failures
A failed trailing cable may result in open circuits, which will be detected by a failure of a component located on the carriage PCA. The following error codes could be caused by a failed trailing cable:
Break in MICCI clock, MICCI data, +5v, +32v or all grounds. C002002F (prior to 5.16), C010xx11, C010xx12, C012xx20, C013xx04, C013000F, C013xx15, C0130016, C013xx44.
Break in digital control lines to the pens. The pen error noted in the keypad. Get error by a 76 tap test if it is generated by CBIO (pen health and safety test).
Mis-installed dimple flex
Codes C013xx27 & C013xx28 indicate a mis-installed dimple flex (the large end).
Bad Spot Sensor
C013xx17 (shorted +5v to Gnd) or C013xx24 (not installed or LED backwards).
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Serbia
- ${title}
hp-hero-support-search
- ${title}
