    Windows 11 Upgrade Guide
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP PSC 1300 All-in-One Printer Series - Setting up the All-in-One (Hardware)
  • Unpack the All-in-One
  • Attach the control panel overlay
  • Connect the power cord and adapter
  • Turn on power
  • Load plain paper
  • Install the cartridges
  • Align the cartridges
Follow these steps in order.
  1. Remove all plastic, tape, and packaging material.
  2. Remove shipping material and components from inside the product.
    Figure : Remove packing material and components
Step three: Attach the control panel overlay
  1. Remove the adhesive backing from the front panel cover.
  2. Raise the lid of the product.
  3. Place the front panel cover into the recess and stick it into place.
The product will not work until the front panel cover is attached.
Step four: Connect the power cord and adapter
Connect the power cord and adapter.
Figure : Connect power cords
Step five: Turn on power
  1. Press the On/Resume button next to the On light ().
    Figure : Press the On/Resume button
  2. Wait 30 seconds for the product to start up.
Step six: Load plain paper
  1. Lower the input tray and slide the paper guide completely to the left.
  2. Insert plain white letter or A4 paper and adjust the paper guide as needed. Be careful not to force the paper too far into the tray.
    Figure : Load plain paper
Step seven: Install the cartridges
  1. With the product still turned on, open the access door. Make sure the carriage movesto the center. If it does not move to the center, turn the product off, thenturn it back on again.
    Figure : Carriage for the cartridges
  2. Remove the tape from both cartridges.
    Figure : Remove the tape
    Do not touch the copper-colored contacts or re-tape thecartridges.
    Figure : Copper-colored contacts
  3. Hold the cartridges with the large HP label and the raised markings on top.
  4. Insert the blackcartridge in the right cartridge slot, and the tri-color cartridge in the left cartridge slot.
  5. Make sure you push the cartridges in firmly until they snap intoplace.
  6. Close the access door.
Step eight: Align the cartridges
  1. After closing the access door, wait a few minutes while the cartridge alignment page prints.
  2. Place the alignment page face down on the left front corner of the glass and close the lid.
    Figure : Load alignment page
  3. Press the Scan button .
    Figure : Press the scan button
  4. After the On light stops blinking, alignment is complete. Discard or recycle the alignment page.
