HP iPAQ Pocket PC h5100, h5400, and h5500 - Charging the Battery
Recharge the battery using the AC adapter with the charger adapter, the universal desktop cradle with the AC adapter, or the optional USB Autosync cable.
Charging with the AC adapter and charger adapter
The standard AC adapter works in any household outlet. Adapters that work in a vehicle's cigarette lighter or a 12-volt power outlet can also be purchased.
Use only HP recommended AC adapters. Failure to do so may damage the iPAQ Pocket PC.
To charge the HP iPAQ Pocket PC using the AC adapter, do the following:
  1. Plug one end of the AC adapter into an electrical outlet.
  2. Plug the other end of the AC adapter into the bottom of the charger adapter.
  3. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
      Figure : Charging the battery
    1. AC adapter into electrical outlet
    2. AC adapter into charger adapter
    3. Charger adapter into charging port
  4. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
The amber charge light blinks while the battery is recharging and  turns solid (nonblinking) when the battery is fully charged.
In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter
Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.
      Figure : Connecting with the cradle
    1. Nine pin serial connector
    2. USB connector
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable
Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the System tab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery
The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Country: Flag Serbia
