HP iPAQ Pocket PC h1900 Series - Inserting and Using Expansion Cards
The memory and connectivity of the iPAQ Pocket PC can be expanded. Optional expansion cards can enable the iPAQ Pocket PC to connect to the internet or a network through a cable or wireless connection, add functionality such as a digital camera, expand the memory of the iPAQ Pocket PC, and view the content of memory cards.
Expansion cards must be purchased separately and are not included with the iPAQ Pocket PC.
Expansion Card Specifications
Feature
Specification
Voltage
3.3V
Transfer rate
15 to 20 Mbits/s (Pure Hardware rate, does not include driver and OS overhead)
Controller
MMC Controller (1-bit transmit/receive)
Pins
9
Installing a Secure Digital (SD) expansion card
Follow these steps in the order in which they are presented to install an SD card into the expansion slot on the iPAQ Pocket PC:
  1. Locate the slot on the top of the iPAQ Pocket PC.
  2. Remove the protective plastic card.
  3. Insert the expansion card into the expansion slot and push the connection edge of the card firmly into the expansion slot.
    Figure : Installing an expansion card
If the expansion card is not recognized, follow the card manufacturer's instructions to install it.
For more detailed help, tap Help from the Start menu, then tap Connections.
Removing a Secure Digital (SD) expansion card
To prevent power loss, remove any expansion cards from the SDIO expansion slot before turning off the iPAQ Pocket PC. Leaving the expansion card in can drain the unit.
  1. Close all applications that are using the expansion card.
  2. Gently push down on the card in the expansion slot to unlock it.
    Failure to unlock an SD card before removing it from the expansion slot may cause damage to the card or the iPAQ Pocket PC.
  3. When the card disengages and pops up, pull it from the expansion slot.
      Figure : Removing an SD expansion card
    1. Unlocking the expansion card
    2. Removing the expansion card
Viewing the content of memory cards
Use File Explorer to view the files that are located on the optional Secure Digital card.
  1. From the Start menu, tap Programs, and File Explorer.
  2. Tap the root directory of My Device, and select the Storage Card folder (SDIO) to see a list of files and folders.
