HP iPAQ Pocket PC h1900 Series - Using Applications
Opening programs
Open any program on the iPAQ Pocket PC from the Start menu.
A program can also be opened by assigning it to a button.
To open a program
  1. Tap Start, then Programs.
  2. Tap the desired program title or logo. (The screen may differ by model.)
    Figure : Programs screen
Minimizing programs
To minimize an open program, tap the X at the top right of the screen.
Closing programs
Programs automatically close based on available memory. However, if the iPAQ Pocket PC is running slowly, programs can be closed manually.
  1. From the Start menu, tap Settings, System tab, then Memory.
  2. Tap Running Programs. (The screen may differ by model.)
    Figure : Running programs button
  3. Tap Stop All or select a particular program and tap Stop.
To bring a currently running program to the foreground, tap Activate.
Installing programs
Install programs on the iPAQ Pocket PC from the following devices:
  • Personal computer by using Microsoft ActiveSync.
  • iPAQ Pocket PC if the program file has a .cab extension.
  • iPAQ Pocket PC or a computer by copying an program file that has an .exe or .cef extension.
When installing programs, look for the correct version for your iPAQ model and Microsoft PPC 2003 Pro.
  • Follow the instructions provided with the program and by the installation wizard to install programs from the personal computer.
  • Tap the program file in File Explorer on the iPAQ Pocket PC and follow the instructions on the installation wizard to install programs on the Pocket PC.
Country: Flag Serbia
