HP Designjet Printers - Using the Color Correction Wizard
The Color Correction Wizard allows the user to choose by example the kind of color correction to apply to pictures.
To use the Color Correction Wizard, go to the printer's Color properties page, select User-defined color correction, then click Start Color Correction Wizard button. The Color Correction Wizard helps the user perform the following steps:
  1. Choose the sample picture to be used. This can be the document that's open in the current application, or one of several samples provided by Hewlett-Packard.
  2. Choose the type of correction to be applied to the picture. The brightness, the contrast, or the color balance can be varied.
  3. The Wizard prints the same picture ten times with different degrees of correction applied to it.
  4. Look at the printout and decide which of the ten is preferred.
A combination of corrections of different kinds can be used. For example, when selecting a brightness correction, the Wizard can be instructed to give another set of ten prints from which to select the contrast, or the color balance.
When the final selection is made, the combination of corrections that have been chosen will be saved. This combination may be saved and used in future whenever selecting User-defined color correction.
