HP Deskjet 9300 Series Printer - Printing Internal Tests
This document explains how to print the built-in (internal) tests of the HP Deskjet 9300 series printer. These tests can be used to ensure the printer is working properly or to troubleshoot specific printer issues. The internal tests will not verify whether the computer-to-printer connection is working properly, except when the sample page is generated from the Toolbox.
All internal test pages can be printed without being connected to a computer. This allows you to test that the printer is set up and operating correctly.
Printing a sample page
It is possible to print a sample page without being connected to a computer. Printing the sample page verifies the printer is set up correctly but does not ensure the printer and computer are properly connected.
  1. Turn the printer off, wait a few seconds, and then turn it on again by pressing the Power button.
  2. Press and hold the Resume button and release it when the Resume light starts to blink. A sample page should print.
The sample page can also be printed from the Toolbox (provided the Toolbox is installed) to verify that the printer is connected to the computer properly and that the printer and printer software are working properly.
  1. Double-click the Toolbox icon on the Desktop or run it from the HP Deskjet 9300 Printer program group.
  2. Select the Printer Services tab and click Print a Test Page (see Figure 1).
Printing a diagnostic page
This diagnostic page is useful to HP Technical Support if there is a printer problem.
  1. Turn the printer on.
  2. While holding down the Power button, press the Resume button four times and then release the Power button.
  3. The diagnostic page should print. If the diagnostic page fails to print, contact the HP Customer Care Center.
Running the pen recovery diagnostic test
If printouts have incomplete text or graphics that are not corrected by cleaning the print cartridges, use the pen recovery diagnostic test. The pen recovery diagnostic test is a three-level cleaning procedure that attempts to clear blocked print cartridge nozzles. The tests can be run either from the Toolbox under Printer Services or by pressing the button sequences below.
The Level 1 print cartridge cleaning is a light cleaning mode. Use this level first to clear blocked nozzles.
  2. Press and hold the Power button while pressing the Cancel button twice and then release the Power button.
After running the Level 1 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If there are irregular gaps in the printout, run the Level 2 pen recovery.
The Level 2 cleaning is an intermediate cleaning mode to be used if the Level 1 mode does not recover the nozzles.
  2. Press and hold the Power button while pressing the Cancel button twice and the Resume button once and then release the Power button.
After running the Level 2 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If there are irregular gaps in the printout, run the Level 3 pen recovery.
The Level 3 cleaning is the most intensive cleaning mode that takes about two minutes to complete. Use this level as a last resort in recovering clogged nozzles. This routine uses a considerable amount of ink.
  2. Press and hold the Power button while pressing the Cancel button twice and the Resume button twice and then release the Power button.
After running the Level 3 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If irregular gaps still appear in the printout, replace the cartridge.
Do not use the pen recovery tests unnecessarily or the life of the print cartridge will be shortened.
This test prints a pattern to determine which nozzles, if any, are clogged or not firing and can be used to verify a successful cleaning routine. Look for irregular spaces or gaps in the test pattern; these indicate faulty nozzles.
  2. Press and hold the Power button while pressing the Cancel button eight times and the Resume button four times and then release the Power button.
Printing the calibration page
This test provides calibration of the print cartridges. Calibration includes print cartridge alignment and optimizing the turn-on energy for the installed color print cartridge.
  2. Press and hold the Power button while pressing the Resume button three times and then release the Power button.
Eight green checks, one on each line of the printout, signify that the calibration was successful.
When a print cartridge is removed from the printer then reinserted or replaced, the printer will automatically run an alignment and print the calibration page.
Printing the infinite H test
This test prints continuous pages of the letter H and is useful for troubleshooting paper feed problems or other intermittent problems that are difficult to replicate.
  2. Press and hold the Power button while pressing the Resume button eight times and then release the Power button.
  3. Press and release the POWER button to terminate the test.
