HP Workstation xw4100 - System Specifications
System specifications
Physical characteristics
U.S.
Metric
Tower dimensions (H x W x D)
17.7 in. x 6.6 in. x 17.9 in.
45.0 cm x 16.8 cm x 45.6 cm
Weight (standard configuration)
35 lbs.
16 kg.
Power supply
Rated line frequency
50 to 60 Hz
Rated input current
  • 3.6 A @ 115 VAC
  • 1.8 A @ 230 VAC
Maximum rated power
  • 412 W input
  • 280 W output
Temperature
Operating
10 degrees to 35 degreesC / 50 degrees to 95 degrees F
Non-operating
-30 degrees to 60 degreesC / -22 degrees to 140 degrees F
Humidity (non-condensing)
Operating
15 percent to 80 percent
Non-operating
10 percent to 90 percent
Maximum altitude (nonpressurized)
Operating
3,048 m / 10,000 ft
Non-operating
4,572 m / 15,000 ft
