    We are upgrading our website
HP PageWide Enterprise Color 556, MFP 586 - Removal and replacement: Left door
This document provides the procedures to remove and replace the left door.
Mean time to repair: 10 minutes
Service level: Basic
Before performing service
Turn the printer power off
  • Disconnect the power cable.
      warning:
Use the table below to identify the correct part number for your printer. To order the part, go to www.hp.com/buy/parts.
Left door kit part number
G1W39-67926
Left door with instruction guide
Required tools
  • No special tools are needed to remove or install this assembly.
After performing service
Turn the printer power on
  • Connect the power cable.
Post service test
No post service test are available for this assembly.
  1. Remove the left door.
    1. Release the latch (callout 1), and then open the left door.
      Figure : Open the left door
    2. Remove the ink collection unit.
      Figure : Remove the ink collection unit
    3. Raise the door slightly and unhook each restraining strap by twisting the bottom end of the strap away from the door.
      Figure : Unhook each restraining strap
    4. Underneath the rear door hinge, locate the catch lever. Press the catch lever toward the rear of the printer and hold it in the released position.
      Figure : Press and hold the catch lever
    5. While holding the catch lever in the released position, raise the door to a 45-degree angle. Rotate the rear side of the door to the right (callout 1), and then slide the door to the left (callout 2) to remove it.
      Figure : Remove the left door
  2. Unpack the replacement assembly.
    1. Dispose of the defective part.
    2. Unpack the replacement part from the packaging.
      If the replacement part is a roller or pad, avoid touching the spongy part of it. Skin oils on the roller or pad can cause paper pickup and/or print-quality problems. HP recommends using disposable gloves when handling rollers or pads or washing your hands or before touching rollers or pads.
      Make sure that all of the shipping materials (for example shipping tape) are removed from the replacement part prior to installation.
  3. Install the left door
    1. Position the shaft on the left door into the opening in the printer (callout 1), and then rotate the door toward the printer (callout 2).
      Figure : Install the left door
    2. Underneath the rear door hinge, press the catch lever toward the rear of the printer and hold it in the released position. Position the door against the printer, and then release the catch lever hinge shaft into the opening in the door.
    3. Reattach each restraining strap by positioning the top of the strap on the hinge post, and then twisting the bottom end of the strap toward the door.
      Figure : Reattach each restraining strap
    4. Reinstall the ink collection unit.
      Figure : Reinstall the ink collection unit
    5. Close the left door.
      Figure : Close the left door
Country/Region: Flag Romania
