Samsung Xpress Color MFP SL-C480 - Replacing the Imaging Unit
This document explains how to replace the imaging unit. When the imaging unit has reached the end of its life, the Printing Status window appears on the computer, indicating the imaging unit needs to be replaced.
  • Do not use sharp objects such as a knife or scissors to open the imaging unit package. They might scratch the surface of the imaging unit.
  • Be careful not to scratch the surface of the imaging unit.
  • To prevent damage, do not expose the imaging unit to light for more than a few minutes. Cover it with a piece of paper to protect it if necessary.
  • Before closing the front cover, make sure all toner cartridges are installed properly.
Replacing the imaging unit
Use these steps to replace the imaging unit.
  1. Open the front cover.
    Figure : Open the front cover
  2. Remove the toner cartridges by pulling on the handles.
    Figure : Pulling on the handles to remove toner cartridges
  3. Remove the waste toner tank by pulling on the handle.
    Figure : Pulling the waste toner tank by handle
  4. Pull the imaging unit straight out using the groove.
    Figure : Pulling the imaging unit straight out
  5. Remove the new imaging unit from the packaging, and then push the new imaging unit into the printer using the groove.
    Figure : Removing new imaging unit from packaging, and then inserting into grooves
    Be careful opening the packaging of the imaging unit. Any scratches or excessive light exposure causes damage to the imaging unit.
  6. Reinsert the waste toner tank.
    Figure : Reinserting the waste toner tank
  7. Slide the toner cartridges back into the printer, matching the proper colors.
    Figure : Reinserting the toner cartridges
  8. Close the front cover, and then resume printing.
    Figure : Closing the front cover
Country/Region: Flag Romania
