HP Pavilion 22fi IPS LED Backlit Monitor - Product Specifications
The HP Pavilion 22fi is a 54.6 cm (21.5 inch) IPS LED Backlit monitor.
Figure : Photo of the HP Pavilion 22fi IPS LED Backlit Monitor
C8H77AA/C8H77AS/C8H77A2
Features
The 22fi IPS LED Backlit Monitor has the following features:
  • VGA, DVI-D and HDMI inputs
  • BrightView Panel
  • Supports High-bandwidth Digital Content Protection (HDCP) to prevent transmission of non-encrypted high definition content
  • Plug and Play capability, if supported by your computer system
  • On-screen display (OSD) adjustments for ease of setup and screen optimization
  • Security lock
Technical specifications
LED feature
Specification
Display size
54.6 cm (21.5 inch) diagonal
Panel active area (width x height): 47.6 cm x 26.7 cm (18.7 inches x 10.5 inches)
Display type
IPS with LED Backlight
Aspect ratio
16:9
Brightness
250 nits
Inputs
1 VGA
1 DVI-D
1 HDMI
Scanning frequency
Horizontal scan range 24-94 KHz
Vertical scan range 50-76 Hz
Viewing angle
Horizontal viewing angle (typical): 178 degrees
Vertical viewing angle (typical): 178 degrees
Recommended resolution (H x V)
1920 x 1080 @ 60 Hz (Full HD) (same as max resolution)
Static contrast ratio
Up to 1000:1
Dynamic contrast ratio
Up to 10,000,000:1
Response time
7 ms Grey-to-Grey (GtG) with overdrive
Pixel pitch
0.248 (H) mm x 0.248 (V) mm
Pixels per inch
102
Color gamut
72% of NTSC
HDCP (High-bandwidth Digital Content Protection)
Yes
Power and Operating Specs
External power supply
Power consumption: 28 Watts max power consumption (26 Watts typical power consumption) , 0.5 Watt energy saving mode
Operating environment
Temperature: 5 degrees C to 35 degrees C (41 degrees F to 95 degrees F)
Humidity: 20% RH through 70% RH
Storage environment
Temperature: -20 degrees C to 60 degrees C (-4 degrees F to 140 degrees F)
Humidity: 20% RH through 90% RH
Dimensions
H x W x D (unpacked):
38.5 x 49.9 x 17.1 cm (15.1 x 19.6 x 6.7 inches)
Unpacked: 3 Kg (6.6 lbs)
Country: Flag Romania
