HP 541 Notebook PC - Specifications
Hardware Specifications
Features
Dimensions (HxWxD)
  • 1.21 inches (at front) x 13.3 x 9.7 inches
  • 30.8 (at front) x 338.0 x 246.4 mm
Starting at 5.0 lb (2.27 kg)
Height varies depending upon where on the notebook the measurement is made. Weight varies by configuration and components. Weight includes 6 cell battery, 80 GB hard drive, 512 MB memory, and optical drive. Weight varies by configuration and components.
Stand-Alone Power Requirements (AC Power)
  • Nominal Operating Voltage: 18.5 V
  • Average Operating Power: 12.5 W
  • Max Operating power: < 65 W
Temperature
Operating:
  • 32 degree to 95 degree F (0 degree to 35 degree C) (not writing optical)
  • 41 degree to 95 degree F (5 degree to 35 degree C) (writing optical)
Non-operating: –4 degree to 140 degree F (–20 degree to 60 degree C)
Relative Humidity
Operating: 10% to 90%, non-condensing
Non-operating: 5% to 95%, 101.6 degree F (38.7 degree C) maximum wet bulb temperature
Shock
Operating: 125 G, 2 ms, half-sine
Non-operating: 200 G, 2 ms, half-sine
Random Vibration
Operating: 0.75 grms
Non-operating: 1.50 grms
Altitude (unpressurized)
Operating: –50 to 10,000 ft (–15.24 to 3,048 m)
Non-operating: –50 to 40,000 ft (–15.24 to 12,192 m)
Communications
Features
HP Integrated Module with Bluetooth Wireless Technology
  • Bluetooth Specification: 2.0 Compliant
  • Dimensions: 1.02 x 0.55 x 0.22 in (26 x 14 x 5.7 mm)
  • Bluetooth Software Supported:
    • Broadcom Bluetooth for Windows
    • Microsoft Windows XP Bluetooth Software
V.92 56K Data/Fax Modem
Form Factor MDC: 1.5 Daughtercard
Power Management Support: APM Revision 1.2, ACPI
Audio
Features
Audio
  • High Definition Audio support
  • Integrated mono speaker
  • Stereo headphone/line out
  • Stereo microphone in
Power
Features
Power Conservation
  • Hibernation
  • Standby
  • ACPI compliance
Wireless Devices
Support for a broad range of secure, integrated wireless LAN and wireless WAN options featuring support for the latest industry standards. Wireless LAN is factory configurable or available as an option to be added later. Broadband Wireless (WWAN) requires Windows Vista Business or Windows XP Professional and is available in select countries as a standard, factory configurable feature only. Integrated Bluetooth is also available (factory configurable only) and can be combined with any of the supported wireless LAN and wireless WAN options.
Features
All 802.11 integrated wireless LAN options
  • Wi-Fi certified
  • Cisco Compatible Extensions support (Version 4.0) with Microsoft Windows XP
  • Wired Equivalent Privacy (WEP) support up to 128-bit keys
  • Wi-Fi Protected Access (WPA) and WPA2 support
  • 802.1x authentication support, including EAP-TLS, EAP-TTLS, PEAP-GTC, PEAP-MSCHAPv2, and LEAP
  • Advanced Encryption Standard (AES) support
  • Dual antennas integrated in the display enclosure
Intel Wireless WiFi Link 4965AGN*
Integrated support for 802.11a, b, g, and draft-n Up to 243 mbps data rate
Intel Wireless WiFi Link 4965AG*
Integrated support for 802.11 a, b and g Up to 54 mbps data rate
Intel PRO/Wireless 3945ABG Network Connection*
Intel PRO/Wireless 3945BG Network Connection*
Integrated support for 802.11 b and g Up to 54 mbps data rate
Broadcom 4311AGN 802.11a/b/g/draft n WiFi Adapter
Broadcom 4311BG 802.11b/g WiFi Adapter
Bluetooth Specification v2.0 compliant Works with a wide range of Bluetooth devices
* Requires Intel Core 2 Duo processor
Expansion card slots
Features
ExpressCard/54 slot
  • Supports ExpressCard/54
  • ExpressCard/34
Country/Region: Flag Romania
