HP LaserJet Pro MFP M329, M428-M429, M479 - Set up Scan to Network Folder
The Scan to Folder feature allows you to scan a document directly to network folder. The printer must be connected to a network, and the Scan to Folder feature must be set up by a network administrator before it can be used.
There are two methods for configuring the Scan to Network Folder feature, the Scan to Network Folder Wizard (Windows), which is installed in the HP program group for the printer as part of the full software installation, and the Network Folder Setup through the HP Embedded Web Server (EWS).
Before you begin
To set up the Scan to Network Folder feature, the network administrator needs access to the printer and information about the network path and destination folder. The printer must have an active network connection to the same network as the computer that will run the setup process.
Administrators need the following information before beginning the configuration process:
  • Administrative access to the printer
  • The network path of the destination folder (e.g., \\servername.us.companyname.net\scans)
    observação:
    The network folder must be set up as a shared folder for the Scan to Network Folder feature to work.
Next steps
After you have set up and configured your HP Scan to Network Folder feature, see the following topic to learn more and get started:
Scan to a network folder - Learn how to use the printer control panel to scan a document and save it to a folder on the network.
País/região: Flag Portugal
