  • Informações
    Informações
    Informações
  • Comentários
HP Thunderbolt Dock G2 Specifications
Product image
Figura : HP Thunderbolt Dock G2
DisplayPort (DP) 1.2/1.3 Thunderbolt host specifications
No. of monitors
Resolution
Supported configurations
1
4096 x 2160 at 60 Hz
(1) DisplayPort port
(1) Thunderbolt port
(1) USB-C video port
2
(1) DisplayPort port and (1) Thunderbolt port
(1) USB-C video port and (1) Thunderbolt port
3
(1) 4096 x 2160 at 60 Hz
(2) 2560 x 1440 at 60 Hz
(2) DisplayPort ports
(1) USB-C video port and (1) DisplayPort port
DisplayPort (DP) 1.3
1
5120 x 2880 at 60 Hz
2
2
3840 x 2160 at 60 Hz
3
(2) 4096 x 2160 at 60 Hz
(1) 2560 x 1440 at 60 Hz
DisplayPort (DP) 1.2/1.3 non-Thunderbolt host specifications
No. of monitors
Resolution
1
2
1920 x 1080 at 60 Hz
3
1280 x 1024 at 60 Hz
1
2
3
1920 x 1080 at 60Hz
Dock specifications
Specification
Top components
LED and power button to power or wake host system
observação:
Requires host notebook to support in its BIOS.
Front components
(1) USB-C port with data and power out (15 W)
(1) USB-C cable to connect to host system
Side components
(1) USB 3.0 port (powered)
(1) Combo audio jack
observação:
HP Thunderbolt Dock Audio Module sold separately and required for audio.
Back components
(1) USB-C DisplayPort data and power out port (15 W)
(1) VGA port
(2) USB 3.0 ports
(1) RJ45/Ethernet port
(1) AC adapter connector
Network manageability features
Preboot Execution Environment (PXE)
Wake-on-LAN
MAC Address Pass Through
WLAN-LAN Switching
External monitor support
Up to 4
observação:
Displays sold separately.
Power Delivery (PD) profiles
5 V/5 A
9 V/5 A
12 V/5 A
15 V/5 A
20 V/5 A
Power to system
Up to 100 W
Operating voltage and current
19.7 VDC at 6.1 A/120 W
19.7 VDC at 11.8 A/230 W
Temperature (operating)
0° to 35° C (32° to 95° F)
Relative humidity (operating)
10% to 90% (non-condensing)
Maximum altitude (operating)
0 to 5,000 m (49.2 to 16,404 ft) (unpressurized)
Physical features
Specification
Dimensions
99.06 x 99.06 x 68.58 mm (3.9 x 3.9 x 2.7 in)
0.800 kg (1.76 lb)
País/região: Flag Portugal
