Yes. You can add, move, and rearrange the tiles in the order you want.
On the Home screen, scroll down the screen, and then tap the Personalize tile or button.
Rearrange the tiles: Tap and hold the
List icon
next to the tile you want to move, and then move it to the new location. Tap the back arrow to return to the home screen or tap
Done.
Android: On the home screen, tap and hold a tile, and then move it to the new location.
Your changes are saved automatically.
observação:
Some tiles, such as the Personalize tile or button, are fixed in position and cannot be rearranged or removed.
You can also rearrange tiles from the home screen. Touch and hold the tile you want to move, and then drag it to the desired location.
Turn on or off tiles: Tap the Personalize tile or button, and then tap the toggle to On or Off on the items you want to add (On) or remove (Off) from the home screen. When you finish, tap the back arrow to return to the home screen or tap Done. Your changes are saved automatically.
