  • Informações
    Informações
    Informações
  • Comentários
HP 6360t Mobile Thin Client - Specifications
Physical specifications
Feature
Dimensions (h x w x d)
33.7 (at front) x 322 x 220 mm (1.32 (at front) x 12.68 x 8.66 in)
Starting at:
1.96 kg (4.31 lb) without optical drive
2.11 kg (4.64 lb) with optical drive
observação:
Height varies depending upon where on the notebook the measurement is made. Weight includes 6-cell battery and WLAN. Weight varies by configuration and components.
Electrical specifications
Feature
Stand-alone power requirements (AC power)
Nominal operating voltage:
18.5 V
Average operating power:
TBD W
Maximum operating power:
Less than 65 W
Environmental specifications
Feature
Temperature
Operating:
0° to 35°C (32° to 95°F) (not writing optical)
5° to 35°C (41° to 95°F) (writing optical)
Non-operating:
-20° to +60°C (-4° to +140°F)
Relative humidity
Operating:
10% to 90%, non-condensing
Non-operating:
5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Shock
Operating:
125 G, 2 ms, half-sine
Non-operating:
200 G, 2 ms, half-sine
Random vibration
Operating:
0.75 grms
Non-operating:
1.50 grms
Altitude (unpressurized)
Operating:
-15.24 to 3048 m (-50 to 10,000 ft)
Non-operating:
-15.24 to 12,192 m (-50 to 40,000 ft)
Safety certifications
Feature
Industry standard certifications
UL: Yes
CSA: Yes
FCC compliance: Yes
ENERGY STAR: Select models1
EPEAT: Gold target2
ICES: Yes
Australia/NZ A-Tick compliance: Yes
CCC: Yes
Japan VCCI compliance: Yes
KCC: Yes
BSMI: Yes
CE Marking compliance: Yes
observação:
1: Configurations of the HP 6360t Mobile Thin Client that are ENERGY STAR qualified are identified as HP 6360t Mobile Thin Client ENERGY STAR on HP websites and on the ENERGY STAR website.
Disclaimer: The above-mentioned URL will take you to a non-HP website. HP does not control and is not responsible for information outside of the HP website.
2: EPEAT registered TBD in U.S. EPEAT registration varies by country.
País/região: Flag Portugal
