  • Informações
    Estamos atualizando o nosso site
    Se você encontrar algum erro, tente novamente mais tarde.
    Informações
    O suporte Microsoft para o Windows 7 terminou em 14 de jan de 2020
    - A HP recomenda que você inicie o processo de atualização para o Windows 10 se o seu computador tiver sido testado pela HP. Para mais informações, clique aqui.
    - Se o seu computador não for compatível com a atualização para o Windows 10, podemos ajudar a encontrar o computador perfeito para você. Confira nossas ofertas semanais!
HP EliteBook 2540p Notebook PC - Removing and Replacing the Wireless WAN Module
This document is provided to assist in removing and replacing the wireless WAN module for the HP EliteBook 2540p Notebook PC.
Minimum skill level
Tools required
Small, Phillips-head (P00 and P1) screwdrivers
Parts required
observação:
The replacement part number will vary depending on the wireless WAN module that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
WWAN (Wireless Wide Area Network) HSPA minicard
531993-001 (Modified)
Yes
HSPA WWAN minicard module
574249-001 (Modified)
Yes
WWAN HSPA F3607 MINI
574248-001 (Modified)
Yes
observação:
Summary of instructions
To view a video demonstrating the procedure for removing the wireless WAN module, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library), then select Wireless WAN module from the menu on the upper left hand side of the screen.
Click here to view the wireless WAN module removal video (right-click on the link to open in a new window/tab).
Wireless WAN module removal
      cuidado:
  2. On the bottom of the notebook, loosen the captive P1 Phillips-head screw identified with a wireless icon that secure the wireless module cover to the bottom of the notebook.
  3. Lift the wireless module cover and remove it.
  4. Carefully disconnect the wireless antenna cables from the wireless WAN module by grasping the connectors with a pair of small needle nose pliers or tweezers.
    observação:
    Make careful note of which wireless antenna cable is connected to each terminal on the wireless WAN module for later replacement.
      cuidado:
    Use care when disconnecting the wireless antenna cables from the wireless WAN module. Damaged cables or connectors can degrade notebook performance.
  5. Remove the two 6 mm P1 Phillips-head screws that secure the wireless WAN module to the system board and allow it to release to the spring tension position.
  6. Grasp the wireless WAN module by the edges and pull gently to remove it.
  7. Place the wireless WAN module in a static dissipative bag.
Wireless WAN module replacement
  1. Grasp the wireless WAN module by its edges and remove it from the static dissipative bag.
  2. Align the notch in the wireless WAN module with the key in the wireless WAN module slot on the system board.
  3. At an angle, gently insert the wireless WAN module into its slot on the system board.
  4. Press the wireless WAN module down and replace the two 6 mm P1 Phillips-head screws that secure the wireless WAN module to the system board.
  5. Reconnect the wireless antenna cables to the wireless WAN module and tuck the wireless antenna cables between the base enclosure and system board.
      cuidado:
  6. Toe the wireless module cover into the base enclosure and lower it into position.
  7. Tighten the captive P1 Phillips-head screw identified with a wireless icon that secures the wireless module cover to the bottom of the notebook.
Parts return
País/região: Flag Portugal
