  • Informações
    Informações
  • Comentários
HP LaserJet Pro P1102, P1109 Printers - Loading Paper
This document is for the HP LaserJet Pro P1102, P1102s, P1102w, P1109, and P1109w printers.
  cuidado:
If you try to print on media that is wrinkled, folded, or damaged in any way, a jam might occur.
Priority feed slot
The priority feed slot holds up to 10 sheets of media or one envelope, one transparency, or one sheet of labels or cardstock. Load media with the top forward and the side to be printed on facing up. To prevent jams and skewing, always adjust the side media guides before feeding the media.
Input tray
The input tray holds 150 pages of 75 g/m2 paper, or fewer sheets of heavier media (a 15 mm stack height or less).
Load media with the top forward and the side to be printed on facing up. To prevent jams and skewing, always adjust the side and front media guides.
observação:
When you add new media, make sure that you remove all of the media from the input tray and straighten the entire stack. This helps prevent multiple sheets of media from feeding through the product at one time, reducing media jams.
Tray adjustment for short media (base models only)
To print on media shorter than 185 mm, use the short media extender to adjust your input tray.
  1. Remove the short media extender tool from the storage slot on the left side of the media input area.
    Figura : Remove Short Media Extender
    Image: Remove Short Media Extender
  2. Attach the tool to the adjustable media guide.
    Figura : Attach Short Media Extender
    Image: Attach Short Media Extender
  3. Insert the media into the product until it stops, and then slide the adjustable media guide, with the tool attached to support the media.
    Figura : Adjust Short Media Extender
    Image: Adjust Short Media Extender
  4. When finished printing with short media, remove the short media extender tool, and then place it back in the storage slot.
País/região: Flag Portugal
