Flickering white spots appear on the touch mat if the projector brightness setting is too low.
To eliminate the flickering white spots, increase the projector brightness.
Select Control Panel > Sprout Settings.
Set the brightness control to Auto.
If that does not help, manually adjust (increase) the brightness until the spots are gone.
nota:The spots, although visible on the mat, will not be captured in images.
