    Solucione errores intermitentes en la cola de impresión/con el spooler de impresión que podrían causar fallos en los trabajos de impresión tras una actualización de Windows. Haga clic aquí
    Corrija errores en Win 10
Removing and Replacing the CD/DVD Drive for HP Pavilion g6-2000, g6-2100, g6-2200 and g6-2300 Notebook PCs
This document applies to HP Pavilion g6-2xxx series notebook computers.
HP Pavilion g6-2x00 series notebook computer
Before you begin
  • You need a Phillips head screwdriver.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  advertencia:
  advertencia:
Before starting, power off the computer and wait for components to cool before starting these procedures.
  atención:
This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
Video overview
The video and graphics in this article depict a specific configuration of notebook computer. These same removal and replacement procedures apply to all configurations for all HP Pavilion g6-2xxx Series PCs.
Removing the CD/DVD drive
  advertencia:
Follow the steps in this section to remove the CD/DVD drive.
Step 1
Remove the battery.
For more information about removing the battery, refer to the HP support document Removing and Replacing the Battery.
Removing the battery
Step 2
Remove the service cover.
For more information about removing the service cover, refer to the HP support document Removing and Replacing the Service Cover.
Removing the service cover
Step 3
Remove the screw that secures the CD/DVD drive to the computer.
Save the screw for drive replacement.
CD/DVD drive screw
Step 4
Using a small, non-metallic tool, press on the rear edge of the CD/DVD drive to free the CD/DVD drive from its connector.
Pushing out the CD/DVD drive
Step 5
Pull the CD/DVD drive out of the CD/DVD drive bay.
Replacing the CD/DVD drive
Use the steps in this section to replace the CD/DVD drive.
Step 1
Insert the CD/DVD drive into the CD/DVD drive bay until the tray door bezel is flush with the side of the base enclosure.
Inserting the CD/DVD drive
Step 2
Replace the CD/DVD drive screw.
CD/DVD drive screw
Step 3
Replace the service cover.
For more information about replacing the service cover, refer to the HP support document Removing and Replacing the Service Cover.
Sliding the service cover in
Step 4
Replace the battery.
For more information about replacing the battery, refer to the HP support document Removing and Replacing the Battery.
Pressing down on the battery
País/región: Flag Puerto Rico
