    Solucione errores intermitentes en la cola de impresión/con el spooler de impresión que podrían causar fallos en los trabajos de impresión tras una actualización de Windows. Haga clic aquí
    Corrija errores en Win 10
Removing and Replacing the Service Cover for HP Pavilion g6-2000, g6-2100, g6-2200 and g6-2300 Notebook PCs
This document applies to HP Pavilion g6-2xxx series notebook computers.
HP Pavilion g6-2x00 series notebook computer
Before you begin
  • You need a Phillips head screwdriver.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  advertencia:
  advertencia:
Before starting, power off the computer and wait for components to cool before starting these procedures.
  atención:
This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
Video overvie
The video and graphics in this article depict a specific configuration of notebook computer. These same removal and replacement procedures apply to all configurations for all HP Pavilion g6-2xxx Series PCs.
Removing the service cover
  advertencia:
Follow the steps in this section to remove the service cover.
Step 1
Remove the battery.
For more information about removing the battery, refer to the HP support document Removing and Replacing the Battery.
Removing the battery
Step 2
Loosen the captive Phillips head screw that secures the service cover to the base enclosure.
Service cover screw
Step 3
Slide the service cover toward the front of the computer.
Sliding the service cover
Step 4
Lift the right side of the service cover and remove the tabs on the left side of the service cover from the cut outs in the base enclosure.
Lifting the service cover
Step 5
Remove the service cover.
Replacing the service cover
Use the steps in this section to replace the service cover.
Step 1
Align the tabs on the left side of the service cover into the cut outs in the base enclosure.
Aligning the service cover
Step 2
Align the service cover in place.
Step 3
Slide the service cover towards the rear of the computer until it is properly seated.
Sliding the service cover in
Step 4
Tighten the captive Phillips head screw that secures the service cover to the base enclosure.
Service cover screw
Step 5
Replace the battery.
Pressing down on the battery
País/región: Flag Puerto Rico
