Removing and Replacing the Battery for HP Pavilion g6-2000, g6-2100, g6-2200 and g6-2300 Notebook PCs
This document applies to HP Pavilion g6-2xxx series notebook computers.
HP Pavilion g6-2x00 series notebook computer
Before you begin
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  advertencia:
  atención:
Video overview
The video and graphics in this article depict a specific configuration of notebook computer. These same removal and replacement procedures apply to all configurations for all HP Pavilion g6-2xxx Series PCs.
Removing the battery
  advertencia:
Follow the steps in this section to remove the battery.
Step 1
On the bottom of the notebook, slide the battery release latch into the release position to partially eject the battery.
The release latch is identified by a battery icon.
Sliding the release latch
Step 2
Lift the front end of the battery and remove from the computer.
Replacing the battery
Use the steps in this section to replace the battery.
Step 1
Toe the bottom outer edge of the battery into the battery bay.
Aligning the battery
Step 2
Press down on the inner edge of the battery until it clicks into place.
Pressing down on the battery
País/región: Flag Puerto Rico
