    ¿Necesita ayuda con Windows 11?
    Vea información sobre compatibilidad, actualización y soluciones para problemas conocidos de HP y Microsoft. Centro de soporte de Windows 11
  • Comentarios
HP Photosmart 7510 e-All-in-One Printer Series (C311) - Setting up the All-in-One (Hardware)
  • Unpack the product
  • Connect the power cord and turn on the power
  • Select the language and location
  • Set the time zone, time, and date
  • Insert the cartridges
  • Load paper
Follow these steps in the order provided to set up the printer hardware.
  atención:
Do NOT connect the USB cable now. If you need a USB cable to connect the product to the computer, you will be prompted to connect it at the correct time during software installation.
Step one: Check the contents of the box
Step two: Unpack the All-in-One
  1. Remove all tape and packing material from the product.
    Figura : Remove all packing materials
    Image: Remove all packing materials
  2. Open the cartridge access door, and then remove the tape from inside the product.
    Figura : Open the cartridge access door, and then remove the tape from inside the product
    Image: Open the cartridge access door, and then remove the tape from inside the product
  3. Close the cartridge access door.
Step three: Connect the power cord and turn on the All-in-One
  1. Connect the cord attached to the power adapter to the rear of the product, connect the power cord to the power adapter, and then plug the power cord into a wall outlet.
      Figura : Connect the power cord to the product
      Image: Connect the power cord to the product
    1. Connect the cord from the power adapter to the product.
    2. Connect the power cord to the power adapter.
    3. Connect the power cord to a wall outlet.
  2. Press the Power button () to turn on the product.
    Figura : Press the Power button
    Image: Press the Power button
Step four: Select your language and country/region
When you turn on the product, it prompts you to select your language and region. Follow these steps to set the default language and country/region for your product.
  1. Touch your desired language, and then touch Yes to confirm the language choice. The Set Region Menu displays.
  2. Touch your desired country/region, and then touch Yes to confirm the country/region choice.
Step five: Set the time zone, time, and date
The product prompts you to select your time zone. Follow these steps to set the default time zone for your product.
If you need to return to the previous screen, touch the Back icon ().
  1. Touch your desired time zone. The Set Time screen displays.
  2. Touch the Up Arrow () or the Down Arrow () to set the correct hour and minutes.
  3. Touch AM or PM.
  4. Touch Daylight Saving if you are in a time zone that adjusts for daylight saving.
  5. Touch OK to confirm the time that you set.
  6. Using the numbers on the control panel, touch the numbers for the current month, day, and year, and then touch OK.
Step six: Install the cartridges
  1. Open the cartridge access door. The carriage moves to the access area.
  2. Remove the protective cap from the carriage.
    Figura : Remove the protective cap from the carriage
    Image: Remove the protective cap from the carriage
  3. Pull the orange tab to remove the plastic wrap from a cartridge.
    Figura : Remove the plastic wrap from a cartridge
    Image: Remove the plastic wrap from a cartridge
  4. Remove the orange cap from the cartridge. Twist the cap counter-clockwise until it snaps off.
    Figura : Remove the orange cap from the cartridge
    Image: Remove the orange cap from the cartridge
  5. With the nozzle and the contacts facing down, push the cartridge into its slot. Press down on the cartridge until it clicks into place. Make sure that the color icon on the cartridge label matches the color icon on the slot.
    Figura : Insert the cartridge
    Image: Insert the cartridge
  6. Repeat these steps to insert the other cartridges.
  7. Close the cartridge access door.
    Figura : Close the cartridge access door
    Image: Close the cartridge access door
Step seven: Load plain paper
  1. Raise the photo tray.
  2. Slide the paper width guides to their outermost positions.
    Figura : Slide paper width guides to their outermost positions
    Image: Slide paper width guides to their outermost positions
  3. Load a stack of plain paper into the tray with the short edge facing toward the product and the print side down (if the paper has a print side). Push the stack into the tray until it stops.
    Figura : Load paper into the tray
    Image: Load paper into the tray
  4. Slide the paper width guides until they rest against the edges of the paper.
    Figura : Slide the paper width guides against the edges of the paper
    Image: Slide the paper width guides against the edges of the paper
  5. Close the photo tray and the paper tray, pull the tray extender toward you, and then extend the paper catch until it is fully extended.
País/región: Flag Puerto Rico
