- ${title}
- ${title}
- ${title}
- ${title}
Setting Up the Printer Hardware for the HP Officejet 6500A e-All-in-One Printer Series
Unpack the All-in-One
Connect the power cord
Turn on the All-in-One
Load paper in the tray
Set the control panel language
Install the printhead
Install the cartridges
Setting up the All-in-One
Follow these steps in order.
nota:Do not connect a USB cable now. If you plan to use a USB cable to connect the printer to the computer, you will be prompted to connect it at the correct time during the software installation.
Follow these steps to unpack the product.
Remove all tape and packing materials from outside the product.Figura : Remove packing materials from outside the product
Lift the product lid, and then remove all tape and packing materials from inside the product.Figura : Remove packing materials from inside the product
Open the print-carriage access door.
Remove the orange packaging material in the print carriage.Figura : Remove orange packaging material
Turn the product in order to access its rear side.Figura : Turn the product to access rear side
Remove all tape and packing materials from the rear of the product.Figura : Remove the packing materials from the rear of the product
Step two: Connect the power cord
Connect the cord from the power supply into the rear of the product.
Plug the power cord into the power supply.
Plug the other end of the power cord into an electrical outlet.
HP product
Power supply
Electrical outlet
Figura : Connect the power cord -
Step three: Turn on the All-in-One
Press the Power button (
) to turn on the product.
Figura : Press the power button
Step four: Set the language and country/region
Follow these steps to set the language and country/region.
On the product control panel, touch the Down Arrow (
) until the desired language displays.
Touch the desired language, and then touch Yes to accept the language setting.
Touch the Down Arrow (
) until the desired country/region displays.
Touch the desired country/region, and then touch Yes to accept the country/region setting.
Step five: Install the cartridges
Follow these steps to install the cartridges that shipped with your product.
Figura : Cartridges that shipped in the box
Open the cartridge access door.
On one of the cartridges, pull the orange pull-tab straight back to remove the plastic wrap.Figura : Remove the plastic wrap
Twist the orange cap counterclockwise to snap it off the cartridge.Figura : Remove the orange cap
With the cartridge contacts facing the printhead, slide the cartridge into the correct slot. The color-coded icons on the cartridge and in the printhead must match.Figura : Insert the cartridge
Press down on the cartridge until it clicks firmly into place.Figura : Press the cartridge into place
Repeat these steps for each cartridge.
Close the cartridge access door. The carriage moves to the right side of the product.Figura : Close the cartridge access door
Wait while the product aligns the printheads, and then prints an alignment page.Figura : Product alignment page
Step six: Install the duplexer (some models only)
Angle the duplexer to the left side of the product, and then insert the left side of the duplexer into the rear access area.Figura : Angle the duplexer to the left side
Push in the right side of the duplexer until it clicks.Figura : Push in the right side of the duplexer
Step seven: Load paper in the tray
Lift the output tray.Figura : Lift the output tray
Insert the paper print-side down along the right side of the input tray. Make sure that the paper aligns with the right and back edges of the tray and is not higher than the line marking in the tray.
Adjust the paper width guide inward so it rests against the edge of the paper but does not bind the paper.Figura : Load the paper, and then adjust the paper width guide
Close the output tray.Figura : Close the output tray
Pull out the extension on the output tray, and then open the paper catch at the end of the output tray extension.Figura : Pull out the output tray extension
Getting started with ePrint
Now you can stay connected and productive on the go with ePrint. ePrint lets you print directly to your ePrint-enabled HP printer using a smartphone, notebook, or other mobile device. For additional information related to setting up and using ePrint, click the link provided.
HP ePrint
- ${title}
- ${title}
- ${title}
País/región:
Puerto Rico
- ${title}
hp-hero-support-search
- ${title}
