The following steps that must be followed before the printer can print:
Ensure that the ink collector kit is installed for porous substrates, and not installed for non-porous substrates. See The ink collector kit (LX800 only).
Start the printer. See Turn the printer on and off.
Go to the HP Internal Print Server and select Substrate > Load/Unload to open the Printer Configuration window.
Select the printer configuration that you intend to use, and press Next to see the on-screen help.
Load the substrate. Substrate loading instructions are displayed in the HP Internal Print Server window. For more detailed instructions, see Load a roll onto the spindle and Load a roll into the printer.
Press the Load button in the HP Internal Print Server to start the substrate check, then enter the substrate type in the Loaded Substrate window.
nota:If the printer has been idle overnight with substrate loaded, and exposed to high or low temperatures, advance the substrate 13 to 25 cm before printing, to avoid printhead crashes or ink smears on the substrate.
