- ${title}
- ${title}
- ${title}
- ${title}
HP EliteBook 8530p Notebook PC - Removing and Replacing the SIM Card
This document is provided to assist in removing and replacing the SIM card for the HP EliteBook 8530p Notebook PC.
Minimum skill level
Parts required
nota:The SIM Card, (a wireless subscriber identity module) is not an HP part and is provided by a local wireless telephone communications service provider. The SIM slot is located inside the battery bay.
Summary of instructions
To view a video demonstrating the procedure for removing the SIM card, click on the link below. Or use the product video listing on the HP Services Media Library, then select SIM Card from the menu on the upper left hand side of the screen.
Right-click on the video link above to open in a new window/tab.
SIM card removal
Review the safety considerations before performing the steps listed below by clicking on the following link:
atención:
Failure to comply with the precautions could result in damage to your product or loss of data. -
Remove the battery. Click here for instructions on removing the battery.
Press in and release the SIM card to partially eject it from the base enclosure.
Pull the SIM card out of the SIM card slot in the base enclosure.
Place the SIM card in a static dissipative bag.
SIM card replacement
Remove the SIM card from the static dissipative bag.
With the circuit etching facing up, insert and press the SIM card into the SIM card slot in the base enclosure.
- ${title}
- ${title}
- ${title}
País/región:
Puerto Rico
- ${title}
hp-hero-support-search
- ${title}
