HP Compaq 2510p Notebook PC - Overview
Product Description
With a starting weight of just 2.8 lbs/1.29 kg, the HP Compaq 2510p Notebook PC is designed to go where you go, without weighing you down.
Carateristicas del producto
Característica
Specification
Procesador
Intel Core 2 Duo Ultra Low Voltage
Mobile Intel GM965
Memoria
DDR2 SDRAM, 667-MHz, one user accessible SODIMM slot, 512/1024/2048-MB
Hard drive(s)
1.8 in PATA 60/80/100-GB 4200 rpm, HP 3D DriveGuard
Medios extraíbles
Fixed ultra-slim 9.5-mm optical drives: DVD+/--RW SuperMulti DL Drive, DVD/CD-RW Combo Drive, DVD-ROM Drive
Pantalla
12.1-inch diagonal Illumi-Lite WXGA (1280 × 800 and 16M colors)
Gráficos
Mobile Intel GMA X3100, up to 384 MB of shared system memory
Sonido
High Definition Audio, integrated speaker, stereo headphone/line out, stereo microphone in, integrated microphone
Soporte inalámbrico
Optional HP ev2200 1xEV-DO and HP hs2300 HSDPA Broadband Wireless Modules, Intel and Broadcom 802.11a/b/g/draft-n, a/b/g, b/g, Bluetooth 2.0, HP Wireless Assistant
Comunicaciones
Intel Gigabit Network Connection (10/100/1000 NIC), HP Smart Power NIC, 56K v.92 modem
1 Type I/II PC Card slot supports 32-bit CardBus and 16-bit cards or integrated Smart Card Reader, Secure Digital slot
Puertos y Conectores
2 USB 2.0 ports, VGA, stereo microphone in, stereo headphone/line out, 1394a, power connector, RJ-11/modem, RJ-45/ethernet, docking connector for HP 2400/2500 Ultra-Light Docking Station
Input device
Full-sized keyboard, enhanced dual pointing devices (touchpad with scroll zone and pointstick)
Manageability
Intel Centrino Pro processor technology capable, HP Backup and Recovery Manager, HP Client Manager Software, HP OpenView Radia Management Agent, HP Client Management Interface
Seguridad
HP ProtectTools, TPM Embedded Security Chip 1.2, HP Fingerprint Sensor, Symantec Norton Internet Security, optional Smart Card Reader, Kensington lock, HP Privacy Filter support
Dimensions (h × w × d)
0.97 in (at front) x 11.11 in x 8.38 in / 24.7 mm (at front) x 282.3 mm x 212.8 mm
Peso
Starting at weight: 2.8 lbs / 1.29 kg (weight will vary by configuration)
Alimentación
9-cell (83 WHr), 6-cell (55 WHr), or 3-cell (28 WHr) Lithium-Ion battery, 65W HP Smart AC Adapter, HP Fast Charge
Expansion solutions
HP 2400/2500 Ultra-Light Docking Station, External MultiBay II, HP Monitor Stand, HP Adjustable Notebook Stand
Garantía
Limited 3-year,1-year and 90-day warranty options available depending on country, 1-year limited warranty on primary battery
Características del Software
Característica
Descripción
Preinstalado:
  • Genuine Windows Vista Business 32/64
  • Genuine Windows Vista Home Basic
  • Genuine Windows XP Professional
  • FreeDOS
Supported:
  • Genuine Windows Vista Enterprise
  • Genuine Windows 2000
Certified:
SuSe Linux Enterprise Desktop 10
País: Flag Puerto Rico
