  • Comentarios
HP Photosmart C7200 All-in-One Series - Installing the Cartridges
This document contains information about installing and aligning the cartridges.
Video of replacing the cartridges
Use only the cartridges that came withthe HP All-in-One. The ink in these cartridges is speciallyformulated to mix with the ink in the print headassembly at first-time setup.
The following video demonstrates how to replace the cartridges.
The following video demonstrates the steps explained on this page. The outside of the product might look different, but the steps are the same for your product.
If you have trouble viewing the video or to view the video in a different size, click here to play the video on YouTube.
Install the cartridges
Follow the steps below to install the cartridges.
  1. Make sure the HP All-in-One is turned on.
  2. Open the access door by lifting from the front center of the HP All-in-One, until the doorlocks into place.
    Figura : Opening the access door
  3. Squeeze the bottom of each latch to release it, andthen lift the latch.
      Figura : Lifting the latch
    1. Cartridge latch for the black ink cartridge
    2. Cartridge latches for the color ink cartridges
  4. Lift all the six latches.
  5. Match the color and pattern of the cartridge tothe color and pattern above the latches.
  6. Push the black ink cartridge into the first slot onthe left, and close the latch.
    Figura : Black ink cartridge installation
  7. Repeat with each of the color ink cartridges.
    Figura : Color ink cartridge installation
  8. Make sure each latch is secure.
    Figura : All cartridges installed
  9. Close the access door.
    Figura : Closing the access door
Align the cartridges
  1. Press the OK button to start the alignment process.Wait a few minutes for the the product to complete the alignment and print the alignment page.
      atención:
    Do not disconnect or turn off the HP All-in-One during this time. You might hear the HP All-in-One making noises.
  2. After the alignment page is printed, check the display for status, and then press the OK button. Recycle or discard the alignment page.
País/región: Flag Puerto Rico
