    Windows 11
    ¡Cree una cuenta HP hoy!
    Conéctese con el soporte de HP de manera más rápida, administre todos sus dispositivos en un solo lugar, vea la información de garantía y más. Regístrese para obtener una cuenta HP
  • Comentarios
HP Photosmart C5100 Series All-in-One - Install the Cartridges
This document contains information about installing the cartridges.
Video of installing cartridges
The following video demonstrates the steps for replacing ink cartridges.
This video shows the HP Photosmart C5180 e-All-in-One printer, but the steps are the same for your printer.
If you have trouble viewing the video or to view the video in a different size, click here to play the video on YouTube.
Install the cartridges
  atención:
Be sure to use only the cartridges that came with the printer. The inkin these cartridges is specially formulated tomix with the ink in the print head assemblyat first-time setup.
  1. Squeeze the tabs at the bottom of each latch to release it, and then liftthe latch.
    Figura : Opening the cartridge latches
  2. Lift all six latches.
    Figura : All the latches open
    Insert the black ink cartridge into the far-leftstall, and then lower the latch andpush it in firmly until it snaps in place.
    Figura : Install the black ink cartridge
    Repeat this process to install the Yellow,Light Cyan, Cyan, Light Magenta, andMagenta ink cartridges.
    Figura : All the cartridges installed properly
    Match the color and pattern of the cartridge to the colorand pattern on the carriage.
      atención:
    Make sure each latch is secure after installing the cartridge.
  3. Lower the top cover, and follow theprompts on the printer screen to beginthe cartridge initialization.
    A one-time initializationprocess begins after cartridgeinstallation. Mechanical noises duringthis process are normal and will lastabout five minutes. Do not turnoff or disconnect the product during thistime.
País/región: Flag Puerto Rico
