Działania
Trwa ładowanie...
Działania
Trwa ładowanie...
  • Informacja
    Dowiedz się, jak zaktualizować system do Windows 11
    Przewodnik aktualizacji do systemu Windows 11
  • Opinie
Działania
Trwa ładowanie...
WSPARCIE KOMUNIKACYJNE- CUSTOMER ADVISORY
Numer identyfikacyjny (ID) dokumentu: c06179452
Wersja: 7
HP Business Notebooks, Mobile Workstations, and Mobile Thin Clients - HP Introduces HP Battery Health Manager To Help Optimize Battery Health
Data wypuszczenia : 02-Nov-2018
Ostatnia aktualizacja : 02-Nov-2018
OPIS
HP has introduced a new battery management features called HP Battery Health Manager into the BIOS of select business notebooks, mobile workstations, and mobile thin client computers. HP Battery Health Manager is designed to help mitigate the exposure of the notebook battery to key factors that can accelerate battery degradation and swelling over time. The HP Battery Health Manager feature is currently available on the computers listed below as long as the BIOS has been updated to specified versions shown:
To learn more about the different settings in HP Battery Health Manager, please see the HP Knowledge Base Article Using HP Battery Health Manager.
To learn more about battery swelling in lithium-ion batteries, please see the HP Knowledge Base Article on Swelling or Deformation of Notebook Battery.
HP recommends that customers update their BIOS to include the latest version of HP Battery Health Manager and enable HP Battery Health Manager to one of the two options below based on usage environment and/or the age of the notebook.
  • Let HP Manage My Battery Charging
  • Maximize My Battery Health
SELECTING THE RIGHT SETTING:
LET HP MANAGE MY BATTERY HEALTH
What Does It Do: Dynamically changes how the system charges the battery based upon usage conditions and temperature over time, optimizing battery health over the life of the battery.
When Should You Use It: Ideal for a new system or systems less than a year old that are used in a mixed-use environment where the notebook is regularly taken off AC power.
MAXIMIZE BATTERY HEALTH
What Does It Do: Immediately limits the maximum state-of-charge on the notebook battery to 80% resulting in minimal stress on the battery and optimizing battery health over the life of the battery.
When Should You Use It: Ideal for systems greater than 1 year old or that are continually plugged into AC Power or a docking station for a long period of time.
To learn more about how to change setting in HP Power Health Manager, please see the HP Knowledge Base Article Using HP Battery Health Manager.
MINIMUM BIOS REQUIREMENTS FOR HP BATTERY HEALTH MANAGER
HP recommends that customers update their BIOS to the most current version available for their device. The chart below is provided as a reference guide to help customers identify the following:
  1. Minimum BIOS that includes the original version of HP Battery Health Manager.
  2. Minimum BIOS that includes the most updated version of HP Battery Health Manager.
  3. Minimum BIOS that includes the most updated version of HP Battery Health Manager and will change the default setting from Maximize My Battery Duration to the recommended Let HP Manage My Battery Charging.
MINIMUM BIOS / ORIGINAL VERSION OF HP BATTERY HEALTH MANAGER
The original version of the HP Battery Health Manager was implemented in the later part of 2018. The first column in the table below identifies the minimum BIOS that includes the original version of HP Battery Health Manager for each device listed. If your notebook does not have HP Battery Health Manager and you would like to update to the minimum BIOS, HP recommends that customers change the default setting to Maximize My Battery Health due to the age of the notebook:
Default Setting from Factory: Maximize My Battery Duration
Default Setting in BIOS Update: Maximize My Battery Duration
MINIMUM BIOS / UPDATED VERSION OF HP BATTERY HEALTH MANAGER
HP has introduced an updated version of HP Battery Health Manager with an improved algorithm for the Let HP Manage My Battery Charging setting; making it more dynamic in how it charges the battery based upon usage conditions over time. The second column in the table below identifies the minimum BIOS that includes the updated version of HP Battery Health Manager for each device listed. Please note that the updated version of HP Battery Health Manager still has the default setting of Maximize My Battery Duration. HP Recommends that customers change the default setting to Let HP Manage My Battery Health or Maximize My Battery Duration based on usage environment and/or the age of the notebook.
Default Setting from Factory: Let HP Manage My Battery Health
MINIMUM BIOS / UPDATED VERSION OF HP BATTERY HEALTH MANAGERWITH AUTO DEFAULT UPDATE
HP has changed the default settings of HP Battery Health Manager from Maximize My Battery Duration to Let HP Manage My Battery Charging. The third column in the table below identifies the minimum BIOS that includes the updated version of HP Battery Health Manager and that will change the default setting to Let HP Manage My Battery Charging for each device listed.
Default Setting in BIOS Update: Let HP Manage My Battery Health
NOTE: HP Battery Health Manager settings can be changed at any time from the system BIOS settings. If the default setting is changed after the update, future BIOS updates will not attempt to change the setting again. The change to the default settings for Battery Health Manager will only take place once.
ZAKRES
Computers:
The Battery Health Manager (BHM) feature is currently available on these computers as long as the BIOS has been updated to at least the version shown:
Computers
Original BHM- Min BIOS
UpdatedBHM - Min BIOS
Updated BHM With Auto Default Update- Min BIOS -
Updated BHM With Auto Default Update-SoftPaq-
Elite Dragonfly
n/a
01.01.04
01.05.05
Elite x2 1012 G1
1.39
n/a
n/a
n/a
Elite x2 1012 G2 Tablet
1.25
1.31
1.34
Elite x2 1013 G3 Tablet
01.01.01
01.09.01
01.11.01
Elite x2 G4
n/a
01.02.03
01.05.05
EliteBook Folio 1040 G3
1.39
n/a
n/a
n/a
EliteBook 1040 G4
1.25
1.31
1.34
EliteBook 1050 G1
01.01.03
01.09.01
01.11.02
EliteBook 725 G3
1.39
n/a
n/a
n/a
EliteBook 725 G4
1.26
1.31
1.33
EliteBook 735 G5
01.03.01
01.09.01
01.11.00
EliteBook 735 G6
01.01.02
01.02.02
01.05.00
EliteBook 745 G3
1.39
n/a
n/a
n/a
EliteBook 745 G4
1.26
1.31
1.33
EliteBook 745 G5
01.03.01
01.09.01
01.11.00
EliteBook 745 G6
n/a
01.02.02
01.05.00
EliteBook 755 G4
1.26
1.31
1.33
EliteBook 820 G3
1.39
n/a
n/a
n/a
EliteBook 820 G4
1.25
1.31
1.34
EliteBook 828 G3
1.39
n/a
n/a
n/a
EliteBook 830 G5
01.01.04
01.09.01
01.11.01
EliteBook 830 G6
n/a
01.03.03
01.05.03
EliteBook 836 G5
01.01.04
01.09.01
01.11.01
EliteBook 840 G3
1.39
n/a
n/a
n/a
EliteBook 840 G4
1.25
1.31
1.34
EliteBook 840 G5 Healthcare Edition
01.01.04
01.09.01
01.11.01
EliteBook 840 G5
01.001.04
01.09.01
01.11.01
EliteBook 840 G6 Healthcare Edition
n/a
01.03.03
01.05.03
EliteBook 840 G6
n/a
01.03.03
01.05.03
EliteBook 840r G4
01.02.03
01.09.01
01.11.01
EliteBook 846 G5
01.01.04
01.09.01
01.11.01
EliteBook 846r G4
01.02.03
01.09.01
01.11.01
EliteBook 848 G3
1.39
n/a
n/a
n/a
EliteBook 848 G4
1.25
1.31
1.34
EliteBook 850 G3
1.39
n/a
n/a
n/a
EliteBook 850 G4
n/a
1.31
1.34
EliteBook 850 G5
01.01.04
01.09.01
01.11.01
EliteBook 850 G6
n/a
01.03.03
01.05.03
EliteBook Folio G1
1.39
n/a
n/a
n/a
EliteBook x360 1020 G2
1.25
1.32
1.34
EliteBook x360 1030 G2
1.25
1.29
1.34
EliteBook x360 1030 G3
01.01.01
01.08.01
01.11.02
EliteBook x360 1030 G4
n/a
01.02.00
01.05.05
EliteBook x360 1040 G5
01.01.02
01.09.01
01.11.01
EliteBook x360 1040 G6
n/a
01.02.01
01.05.03
EliteBook x360 830 G5
n/a
01.09.01
01.11.01
EliteBook x360 830 G6
n/a
01.03.03
01.05.03
Engage Go Mobile System
n/a
01.09.01
01.11.01
mt20 Mobile Thin Client
1.25
1.31
1.34
mt21 Mobile Thin Client
01.06.00
01.09.01
01.11.01
mt31 Mobile Thin Client
n/a
01.09.01
01.11.01
mt42 Thin Client
1.39
n/a
n/a
n/a
mt43 Mobile Thin Client
1.26
1.31
1.33
mt44 Mobile Thin Client
01.03.01
01.09.01
01.11.00
Pro x2 612 G2
1.25
1.31
1.34
ProBook 11 EE G2
1.39
n/a
1.47
ProBook 430 G3
1.39
n/a
n/a
n/a
ProBook 430 G4
1.25
1.31
1.34
ProBook 430 G5
01.06.00
01.09.01
01.11.01
Probook 430 G6
n/a
01.09.01
01.11.01
ProBook 440 G3
1.39
n/a
n/a
n/a
ProBook 440 G4
1.25
1.31
1.34
ProBook 440 G5
n/a
01.09.01
01.11.01
ProBook 440 G6
01.06.00
01.09.01
01.11.01
ProBook 445 G6
n/a
01.09.00
n/a
n/a
ProBook 450 G3
1.39
n/a
n/a
n/a
ProBook 450 G4
1.25
1.31
1.34
ProBook 450 G5
01.06.00
01.09.01
01.11.01
ProBook 450 G6
n/a
01.09.01
01.11.01
ProBook 455 G3
1.39
n/a
n/a
n/a
ProBook 455 G4
1.25
1.31
n/a
n/a
ProBook 455 G5
01.06.00
01.09.01
n/a
n/a
ProBook 455 G6
n/a
01.09.00
n/a
n/a
ProBook 455R G6
n/a
01.09.00
n/a
n/a
ProBook 470 G3
1.39
n/a
n/a
n/a
ProBook 470 G4
1.25
1.31
1.34
ProBook 470 G5
01.06.00
01.09.01
01.11.01
ProBook 640 G2
1.39
n/a
n/a
n/a
ProBook 640 G3
1.25
1.31
1.34
ProBook 640 G4
01.02.03
01.09.01
01.11.01
ProBook 640 G5
n/a
01.03.03
01.05.03
ProBook 645 G2
1.39
n/a
n/a
n/a
ProBook 645 G3
1.26
1.31
n/a
n/a
ProBook 645 G4
01.03.01
01.09.01
n/a
n/a
ProBook 650 G2
1.39
n/a
n/a
n/a
ProBook 650 G3
1.25
1.31
1.34
ProBook 650 G4
01.02.03
01.09.01
01.11.01
ProBook 650 G5
n/a
01.03.03
01.05.03
ProBook 655 G2
1.39
n/a
n/a
n/a
ProBook 655 G3
1.26
1.31
1.33
ProBook x360 11 G1 EE
1.29
n/a
n/a
n/a
ProBook x360 11 G2 EE
1.25
1.31
1.35
ProBook x360 11 G3 EE
n/a
01.05.00
01.11.00
ProBook x360 11 G4 EE
n/a
01.04.01
01.06.02
ProBook x360 440 G1
01.01.02
01.09.01
01.11.01
ZBook 14u G4
n/a
1.31
1.34
ZBook 14u G5
01.01.04
01.09.01
01.11.01
ZBook 15 G3
1.4
n/a
n/a
n/a
ZBook 15 G4
1.25
1.31
1.34
ZBook 15 G5
01.01.03
01.09.01
01.11.02
ZBook 15 G6
n/a
01.02.02
01.05.04
ZBook 15u G4
1.25
1.31
1.34
ZBook 15u G5
01.01.04
01.09.01
01.11.01
ZBook 17 G3
1.4
n/a
n/a
n/a
ZBook 17 G4
1.25
1.31
1.34
ZBook 17 G5
01.01.03
01.09.01
01.11.02
ZBook 17 G6
n/a
01.02.02
01.05.04
ZBook Studio 14u G6
n/a
01.03.03
01.05.03
ZBook Studio 15u G6
n/a
01.03.03
01.05.03
ZBook Studio G4
1.24
1.31
1.34
ZBook Studio G5
01.01.03
01.09.01
01.11.03
ZBook Studio x360 G5
n/a
01.09.01
01.11.03
ZBook x2 G4
1.25
1.31
1.34
Zhan 66 Pro 13 G2
n/a
01.09.01
01.11.01
Zhan 66 Pro 14 G2
n/a
01.09.01
01.11.01
Zhan 66 Pro 15 G2
n/a
01.09.01
01.11.01
ZHAN 66 Pro G1
01.06.00
01.09.01
01.11.01
ZHAN X 13 G2
n/a
01.03.03
01.05.03
ROZDZIELCZOŚĆ
If the Battery Health Manager option is not present in BIOS settings, update the computer BIOS to the latest version available from HTTPS://support.hp.com.
NOTE: Platforms shipped with the updated version of the Battery Health Manager may have the default setting of “Maximize battery duration”. Updating a platform with the indicated BIOS version will not impact this default setting unless the option of factory reset is selected after the update.
Accessing Battery Health Manager settings
  1. Start or restart the computer.
  2. Press F10 to enter HP Computer Setup (F10 setup).
  3. Select Advanced > Power Management Options.
  4. After selecting an option (see below for explanation of the 3 options), Save and exit F10 setup.
Hardware platforms affected : HP Elite Dragonfly Notebook PCs, HP Elite x2 1012 G1, HP Elite x2 1012 G2, HP Elite x2 1012 G2 Tablet, HP Elite x2 1013 G3, HP Elite x2 1013 G3 Base Model Tablet, HP Elite x2 1013 G3 Tablet, HP Elite x2 1013 G3 Tablet with Keyboard, HP Elite x2 G4, HP EliteBook 1030 G1 Notebook PC, HP EliteBook 1040 G3 Notebook PC, HP EliteBook 1040 G4 Notebook PC, HP EliteBook 1050 G1 Notebook PC, HP EliteBook 725 G3 Notebook PC, HP EliteBook 725 G4 Notebook PC, HP EliteBook 735 G5 Base Model Notebook PC, HP EliteBook 735 G5 Notebook PC, HP EliteBook 735 G5 Notebook PC, HP EliteBook 735 G6 Notebook PC, HP EliteBook 745 G3 Notebook PC, HP EliteBook 745 G4 Notebook PC, HP EliteBook 745 G5 Base Model Notebook PC, HP EliteBook 745 G5 Notebook PC, HP EliteBook 745 G5 Notebook PC, HP EliteBook 745 G6 Notebook PC, HP EliteBook 755 G4 Notebook PC, HP EliteBook 755 G5 Notebook PC, HP EliteBook 755 G5 Notebook PC, HP EliteBook 755 G5 Notebook PC IDS Base Model, HP EliteBook 820 G3 Notebook PC, HP EliteBook 820 G4 Notebook PC, HP EliteBook 828 G3 Notebook PC, HP EliteBook 830 G5 Base Model Notebook PC, HP EliteBook 830 G5 Base Model Notebook PC Bundle, HP EliteBook 830 G5 Notebook PC, HP EliteBook 830 G5 Notebook PC, HP EliteBook 830 G6 Notebook PC, HP EliteBook 836 G5 Base Model Notebook PC, HP EliteBook 836 G5 Notebook PC, HP EliteBook 836 G5 Notebook PC, HP EliteBook 840 G3 Notebook PC, HP EliteBook 840 G4 Notebook PC, HP EliteBook 840 G5 Base Model Notebook PC, HP EliteBook 840 G5 Healthcare Edition Notebook PC, HP EliteBook 840 G5 Notebook PC, HP EliteBook 840 G5 Notebook PC, HP EliteBook 840 G5 Notebook PC Bundle, HP EliteBook 840 G6 Healthcare Edition Notebook PC, HP EliteBook 840 G6 Notebook PC, HP EliteBook 840r G4 Base Model Notebook PC, HP EliteBook 840r G4 Notebook PC, HP EliteBook 840r G4 Notebook PC, HP EliteBook 846 G5 Base Model Notebook PC, HP EliteBook 846 G5 Notebook PC, HP EliteBook 846 G5 Notebook PC, HP EliteBook 846r G4 Base Model Notebook PC, HP EliteBook 846r G4 Notebook PC, HP EliteBook 846r G4 Notebook PC, HP EliteBook 848 G3 Notebook PC, HP EliteBook 848 G4 Notebook PC, HP EliteBook 850 G3 Notebook PC, HP EliteBook 850 G4 Notebook PC, HP EliteBook 850 G4 Notebook PC, HP EliteBook 850 G5 Base Model Notebook PC, HP EliteBook 850 G5 Notebook PC, HP EliteBook 850 G5 Notebook PC, HP EliteBook 850 G5 Notebook PC Bundle, HP EliteBook 850 G6 Notebook PC, HP EliteBook Folio G1 Notebook PC, HP EliteBook x360 1020 G2 Notebook PC, HP EliteBook x360 1030 G2, HP EliteBook x360 1030 G2 Notebook PC, HP EliteBook x360 1030 G3 Base Model Notebook PC, HP EliteBook x360 1030 G3 Notebook PC, HP EliteBook x360 1030 G3 Notebook PC, HP EliteBook x360 1030 G4 Notebook PC, HP EliteBook x360 1040 G5 Base Model Notebook PC, HP EliteBook x360 1040 G5 Notebook PC, HP EliteBook x360 1040 G5 Notebook PC, HP EliteBook x360 1040 G6 Notebook PC, HP EliteBook x360 830 G5 Notebook PC, HP EliteBook x360 830 G6 Notebook PC, HP Engage Go Mobile System, HP Pro x2 612 G2, HP ProBook 11 EE G2, HP ProBook 430 G3 Notebook PC, HP ProBook 430 G4 Notebook PC, HP ProBook 430 G5 Notebook PC, HP ProBook 430 G6 Notebook PC, HP ProBook 440 G3 Notebook PC, HP ProBook 440 G4 Notebook PC, HP ProBook 440 G5 Notebook PC, HP ProBook 440 G6 Notebook PC, HP ProBook 445 G6 Notebook PC, HP ProBook 450 G3 Notebook PC, HP ProBook 450 G4 Notebook PC, HP ProBook 450 G4 Notebook PC, HP ProBook 450 G5 Notebook PC, HP ProBook 450 G6 Notebook PC, HP ProBook 455 G3 Notebook PC, HP ProBook 455 G3 Notebook PC, HP ProBook 455 G4 Notebook PC, HP ProBook 455 G5 Notebook PC, HP ProBook 455 G6 Notebook PC, HP ProBook 455R G6 Notebook PC, HP ProBook 470 G3 Notebook PC, HP ProBook 470 G4 Notebook PC, HP ProBook 470 G5 Notebook PC, HP ProBook 640 G2 Notebook PC, HP ProBook 640 G3 Notebook PC, HP ProBook 640 G4 Base Model Notebook PC, HP ProBook 640 G4 Notebook PC, HP ProBook 640 G4 Notebook PC, HP ProBook 640 G4 Notebook PC Bundle, HP ProBook 640 G5 Notebook PC, HP ProBook 645 G2 Notebook PC, HP ProBook 645 G3 Notebook PC, HP ProBook 645 G4 Notebook PC, HP ProBook 645 G4 Notebook PC, HP ProBook 645 G4 Notebook PC IDS Base Model, HP ProBook 650 G2 Notebook PC, HP ProBook 650 G3 Notebook PC, HP ProBook 650 G4 Base Model Notebook PC, HP ProBook 650 G4 Notebook PC, HP ProBook 650 G4 Notebook PC, HP ProBook 650 G4 Notebook PC Bundle, HP ProBook 650 G5 Notebook PC, HP ProBook 655 G2 Notebook PC, HP ProBook 655 G3 Notebook PC, HP ProBook x360 11 G1 EE Notebook PC, HP ProBook x360 11 G2 EE Notebook PC, HP ProBook x360 11 G3 EE Notebook PC, HP ProBook x360 11 G4 EE Notebook PC, HP ProBook x360 440 G1 Notebook PC, HP ZBook 14u G4 Mobile Workstation, HP ZBook 14u G5 Mobile Workstation, HP ZBook 14u G5 Mobile Workstation, HP ZBook 14u G5 Mobile Workstation Bundle, HP ZBook 14u G5 Mobile Workstation IDS Base Model, HP ZBook 14u G6 Mobile Workstation, HP ZBook 15 G3 Mobile Workstation, HP ZBook 15 G4 Mobile Workstation, HP ZBook 15 G5 Mobile Workstation, HP ZBook 15 G5 Mobile Workstation, HP ZBook 15 G5 Mobile Workstation IDS Base Model, HP ZBook 15 G6 Mobile Workstation, HP ZBook 15u G4 Mobile Workstation, HP ZBook 15u G5 Mobile Workstation, HP ZBook 15u G5 Mobile Workstation, HP ZBook 15u G5 Mobile Workstation IDS Base Model, HP ZBook 15u G6 Mobile Workstation, HP ZBook 17 G3 Mobile Workstation, HP ZBook 17 G4 Mobile Workstation, HP ZBook 17 G5 Mobile Workstation, HP ZBook 17 G5 Mobile Workstation, HP ZBook 17 G5 Mobile Workstation IDS Base Model, HP ZBook 17 G6 Mobile Workstation, HP ZBook Studio G3 Mobile Workstation, HP ZBook Studio G4 Mobile Workstation, HP ZBook Studio G5 Mobile Workstation, HP ZBook Studio G5 Mobile Workstation, HP ZBook Studio G5 Mobile Workstation IDS Base Model, HP ZBook Studio x360 G5 Convertible Workstation, HP ZBook Studio x360 G5 Convertible Workstation, HP ZBook Studio x360 G5 Convertible Workstation IDS Base Model, HP ZBook x2 G4 Detachable Workstation, HP ZHAN 66 Pro 13 G2 Notebook PC, HP ZHAN 66 Pro 14 G2 Notebook PC, HP ZHAN 66 Pro 15 G2 Notebook PC, HP ZHAN 66 Pro G1 Notebook PC, HP ZHAN X 13 G2 Notebook PC, HP mt20 Mobile Thin Client, HP mt21 Mobile Thin Client, HP mt21 Mobile Thin Client series, HP mt31 Mobile Thin Client, HP mt42 Mobile Thin Client, HP mt43 Mobile Thin Client, HP mt44 Mobile Thin Client, HP mt44 Mobile Thin Client
Dotyczy systemów operacyjnych : Niemający zastosowania
Dotyczy oprogramowania : Niemający zastosowania
Odsyłacz do numeru ID wsparcia komunikacyjnego : IA06179452
Działania
Trwa ładowanie...
Działania
Trwa ładowanie...
Kraj/region: Flag Polska
Działania
Trwa ładowanie...
