Działania
Trwa ładowanie...
Działania
Trwa ładowanie...
  • Informacja
    Dowiedz się, jak zaktualizować system do Windows 11
    Przewodnik aktualizacji do systemu Windows 11
  • Opinie
Działania
Trwa ładowanie...
HP OfficeJet 200 Mobile Printer - First Time Printer Setup
This document is for HP OfficeJet 200, 200c, 202, 202c Mobile printers.
To set up a printer for the first time, remove the printer and all packing materials from the box, install the battery, connect the power cable, set control panel preferences, load paper, and then install the ink cartridges. After your printer is set up, download and install the latest print driver.
Uwaga:
If you are looking for the printer software, go to 123.hp.com/OJ200.
Video of setting up the printer
The following video demonstrates how to set up the physical parts of the printer.
Remove the printer from the box and all tape, stickers, remove all packing materials from the printer, and then install the battery.
  2. Remove all tape and packing materials from the outside of the printer.
    Rys. : Removing tape and packing materials
    Image: Removing tape and packing materials
  3. Lift the top cover, and then remove tape from the inside of the printer.
    Rys. : Lifting the top cover and removing tape
    Image: Lifting the top cover and removing tape
  4. Open the ink cartridge access door, and then remove all tape and packing material from inside the printer.
    Rys. : Removing tape and packing materials from inside printer
  5. Recycle the packing materials.
Step 2: Insert the battery
Depending on your printer model and the country/region it was sold in, it may have come with an optional lithium-ion rechargeable battery. If your printer did not come with a battery or you purchased one separately, skip to the next step to connect the power cord.
Uwaga:
To purchase a battery for your printer, visit the HP Store and search for your printer model.
  1. Turn the printer so the rear faces you.
    Rys. : Turning the printer
    Image: Turning the printer
  2. Push the battery cover latch to the right, and then pull the battery cover toward you to remove it.
    Rys. : Removing the battery cover
    Image: Removing the battery cover
  3. Unwrap the battery.
    Rys. : Unwrap the battery
    Image: Unwrap the battery
  4. Slide the battery into its slot, and then press the left side of the battery until it clicks into place.
    Rys. : Pressing on the edge of the battery
    Image: Pressing on the edge of the battery
  5. Slide the battery cover into its slot, and then make sure the left side of the cover clicks into place.
    Rys. : Installing the battery cover
    Image: Installing the battery cover
Step 3: Connect the power cord and set your preferences
Plug the printer into a wall outlet, turn on the printer, and then set your preferences.
Uwaga:
    Rys. : Connecting the power cord and power supply
    Image: Connecting the power cord and power supply
  2. Turn on the printer.
  3. On the printer control panel, press the arrow buttons to select your preferred language and country/region, and then press OK.
    Rys. : Selecting language from the control panel
    Image: Selecting language from the control panel
Load plain, U.S. letter, or A4 paper in the input tray.
  1. Open the top cover, and then lift the control panel.
  2. Slide the two paper-width guides out as far as possible.
    Rys. : Sliding paper-width guides out as far as possible
    Image: Sliding paper-width guides out as far as possible
  3. Load 50 sheets of plain paper or less into the paper tray, and then slide the paper-width guides until they rest against the sides ofthe paper.
    Rys. : Sliding paper-width guides against the paper
    Image: Sliding paper-width guides against the paper
Step 5: Install the ink cartridges
Install the HP ink cartridges that came in the box with your printer.
  1. Open the ink cartridge access door.
    Rys. : Opening the ink cartridge access door
    Image: Opening the ink cartridge access door
  2. Wait until the carriage is idle and silent before you continue.
  3. Remove the ink cartridge from its package. Be careful to only touch the black plastic on the ink cartridge.
    Rys. : Removing the ink cartridge from its package
    Image: Removing the ink cartridge from its package
  4. Remove the plastic tape from the ink cartridge.
      Przestroga:
    Rys. : Removing the plastic tape
    Image: Removing the plastic tape
  5. Insert the ink cartridge into its slot, and then press the ink cartridge until it latches into place.
    Uwaga:
    Install the color ink cartridge on the left and the black ink cartridge on the right.
    Rys. : Closing the ink cartridge latch
    Image: Making sure the ink cartridge is snapped into place
  6. Close the ink cartridge access door.
    Rys. : Closing the ink cartridge access door
    Image: Closing the ink cartridge access door
  7. After installing the ink cartridges, the printer automatically prints an alignment page. Aligning the ink cartridges is necessary to achieve the best print quality.
    If an alignment page did not print, you can manually print an alignment page.
    1. From the home screen on the printer control panel, use the arrow buttons to select Setup, and then press OK.
    2. Press the down arrow to select Tools, and then press OK.
    3. Press the down arrow to select Align Printer, and then press OK.
      Aligning... displays on the control panel. The printer might beep or make mechanical noises, and then the printer prints an alignment page.
Your HP printer hardware is now set up, and you can install the printing software.
Uwaga:
Do not connect the printer to a computer until instructed to do so in the printing software.
Download the latest version of the printing software from 123.hp.com/OJ200.
Działania
Trwa ładowanie...
Działania
Trwa ładowanie...
Kraj/region: Flag Polska
Działania
Trwa ładowanie...
